I have pasted my config and the logs on pastebin due to new user link limitation.
Please search # CONFIG START
and # CONFIG END
to find start and end of config file, and # LOG START
and LOG END
to find start and end of log file.
However, do note that the provided config file uses a different shaper (but otherwise the config is identical):
conanap@octopi:~ $ diff printer.cfg buggy.cfg
155,156c155,156
< shaper_freq_x: 50
< shaper_type_x: mzv
> shaper_freq_x: 73.6
> shaper_type_x: 2hump_ei
I have an Ender 3 Pro with Speeddrive mod (please search on Thingiverse; I am not allowed to post more than 2 links as a new user), which I slightly modified myself to mount an ADXL. I use a Raspberry Pi 4 to host Octopi, and the original board is used with Klipper installed. I also have a CR Touch installed on the carriage.
I have noticed that, intermittently, the x-axis would fail to move all the way to the left, and not trigger the end stopper. I’ve included a video of what this looks like with G28 X
command (home X axis only): Imgur link.
I’m not sure why this happens. When I turn the motors off using the Octoprint UI, I am able to easily move it all the way to the left and trigger the end stopper.
For those who aren’t familiar with the speeddrive mod, it reduces the print area in the X axis on both sides by about 10mm, hence the reduced print size, and the position_max: 210
(just to be safe, I gave it an extra 5mm margin) setting under [stepper_x]
This issue originally only appeared, consistently, with shaper_type_x: 2hump_ei
(accompanying a myriad of other issues that I won’t get into in this specific post - I haven’t been able to gather logs yet for that issue, and I will open another discusison when I am able to), but have since also appeared with shaper_type_x: zv
, albeit intermittently now on both types of shaper.
I’ve physically checked to ensure nothing is blocking the carriage from moving all the way left (despite the cables looking like they are), and as I’ve mentioned above, turning off the motor still allows me to manually move the carriage all the way to the x end stopper without needing much force.
I would appreciate any help and feedback. Please let me know if there are additional information I can provide. Thanks!
