Fairly new to Klipper. Built several printers. Came over from the “dark side - Marlin 2.0”. Have several successful prints via Klipper but am experiencing an issue I can’t resolve. It seems like the printer “assumes” that the X axis is at 0 when the printer powers on. Sometimes that’s correct but not always. Of course when I run home X/Y , since the printer “thinks” the X axis is already homed, it homes Y and Z correctly but the X axis stays in whatever position it might be at and never moves towards the end stop. The printer has optical end stops and is a CoreXY. I have resorted to disabling the steppers, moving the X manually to the end stop, re-enabling the steppers, and homing all axis which then works as expected.
Here is my current printer.cfg (pertinent parts) - any help would be greatly appreciated:
[stepper_x]
step_pin: P2.2
dir_pin: P2.6
enable_pin: !P2.1
full_steps_per_rotation: 200
rotation_distance: 40
endstop_pin: ^P1.29 # P1.28 for X-max
position_endstop: 0
position_min: 0
position_max: 270
homing_speed: 80
homing_retract_dist: 0
[stepper_y]
step_pin: P0.19
dir_pin: !P0.20
enable_pin: !P2.8
endstop_pin: ^P1.27 # P1.26 for Y-max
position_endstop: 0
position_min: 0
position_max: 240
homing_speed: 60
step_pin: P0.22
dir_pin: P2.11
enable_pin: !P0.21
microsteps: 8
position_min: -2
position_max: 275
homing_speed: 10
homing_retract_dist: 10
[stepper_z1]
step_pin: P0.1
dir_pin: P0.0
enable_pin: !P0.10
microsteps: 8
[safe_z_home]
home_xy_position: 0, 0
speed: 50
z_hop: 5
#z_hop: 10
z_hop_speed: 30
step_pin: P2.13
dir_pin: P0.11
enable_pin: !P2.12
microsteps: 8
rotation_distance: 25
#rotation_distance: 0.012620
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: P2.7
sensor_pin: P0.24
min_temp: 0
max_temp: 260
min_extrude_temp: 170
max_extrude_only_distance: 780
max_extrude_cross_section: 50
#pressure_advance: 0.254 # See tuning pressure advance doc
#pressure_advance_smooth_time: 0.040
[firmware_retraction]
retract_length: 4
# The length of filament (in mm) to retract when G10 is activated,
# and to unretract when G11 is activated (but see
# unretract_extra_length below). The default is 0 mm.
retract_speed: 20
# The speed of retraction, in mm/s. The default is 20 mm/s.
#unretract_extra_length: 0
# The length (in mm) of *additional* filament to add when
# unretracting.
unretract_speed: 20
# The speed of unretraction, in mm/s. The default is 10 mm/s.
[heater_bed]
heater_pin: P2.5
sensor_pin: P0.23
min_temp: 0
max_temp: 120
[fan]
pin: P2.3
[heater_fan noozle_fan]
heater: extruder
shutdown_speed: 0
cycle_time: 0.010
kick_start_time: 0.100
heater_temp: 50
fan_speed: 1.0
pin: P2.4
serial: /dev/serial/by-id/usb-Klipper_lpc1768_1980FF16039445AF3E58DE5CC42000F5-if00
restart_method: command
[printer]
kinematics: corexy
max_velocity: 300
max_accel: 3000
max_z_velocity: 30
#max_z_velocity: 25
max_z_accel: 75
#max_z_accel: 55
[virtual_sdcard]
path: ~/.octoprint/uploads/
[bltouch]
sensor_pin: ^P1.25 # Pull-up (^ symbol) needed in open drain mode
control_pin: P2.0
pin_up_touch_mode_reports_triggered: False
set_output_mode: 5V
x_offset: 0
y_offset: 0
#z_offset: 1.78
z_offset: 1.85
speed: 2.0
samples: 2
#probe_with_touch_mode: False
#pin_up_reports_not_triggered: True
#pin_up_touch_mode_reports_triggered: True
[bed_mesh]
speed: 150
horizontal_move_z: 7
mesh_min: 0,0
mesh_max: 250,240
probe_count: 3,3
split_delta_z: 0.025
#move_check_distance: 3.0
move_check_distance: 5.0
mesh_pps: 2,2
algorithm: lagrange
fade_start: 1
fade_end: 10
fade_target: 0
