Printer Model: TRONXY X5SA
MCU / Printerboard: CHITU V6 103 CXY-V6-191017
Host / SBC MAINSAILL con CB1
klippy (9).log (102.8 KB)
[include mainsail.cfg]
[virtual_sdcard]
path: /home/biqu/printer_data/gcodes
on_error_gcode: CANCEL_PRINT
serial:/dev/serial/by-id/usb-1a86_USB_Serial-if0
[printer]
kinematics: corexy
max_velocity: 300
max_accel: 3000
max_z_velocity: 25
max_z_accel: 30
[stepper_x]
step_pin: PE5
dir_pin: !PE6
enable_pin: !PC13
rotation_distance: 20
endstop_pin: !PG10
position_endstop: -1
position_min: -1
position_max: 350
homing_speed: 50
homing_retract_dist: 10
second_homing_speed: 10.0
[stepper_y]
step_pin: PE2
dir_pin: !PE3
enable_pin: !PE4
endstop_pin: !PA12
position_endstop: 0
position_max: 330
homing_speed: 50.0
step_pin: PB9
dir_pin: PE0
enable_pin: !PE1
rotation_distance: 4
position_max: 400
position_min: -2
step_pin: PB4
dir_pin: PB5
enable_pin: !PB8
rotation_distance: 35.520
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PG12
sensor_pin: PA1
control: pid
pid_Kp: 18.831
pid_Ki: 0.821
pid_Kd: 108.044
min_temp: 0
max_temp: 250
max_extrude_only_distance: 300
[heater_bed]
heater_pin: PG11
sensor_pin: PA0
control: pid
min_temp: 0
max_temp: 130
pid_Kp: 73.932
pid_Ki: 1.521
pid_Kd: 898.279
[heater_fan hotend_fan]
pin: PG14
fan_speed: 0.5
[fan]
pin: PG13
max_power: 0.5
[controller_fan drivers_fan]
pin: PD6
[filament_switch_sensor sentinel]
pause_on_runout: True
runout_gcode:
M25
switch_pin: PA15
[output_pin beeper]
pin: PB0
[safe_z_home]
home_xy_position: 165,165
speed: 50
z_hop: 10
z_hop_speed: 5
[bed_screws]
screw1: 5,5
screw2: 165,5
screw3: 325,5
screw4: 5,325
screw5: 165,325
screw6: 325,325
[bed_mesh]
speed: 120
probe_count: 5,5
horizontal_move_z: 5
algorithm: lagrange
mesh_min : 20,20
mesh_max : 310,310
mesh_pps: 0
[probe]
x_offset: -40
y_offset: 0
pin: !PG9
speed: 30
z_offset: 2
I am trying to connect Klipper with my TRONXY X5SA I CANNOT CONNECT THE MCU
