Y homes and x doesnt move
Printer Model: zero g
MCU / Printerboard: kraken
Host / SBC btt pi
Describe your issue: when i home y it homes correctly but when i home x the motors come on but nothing moves
klippy (6).log (1.4 MB)
printer (1).cfg (22.5 KB)
What is the status of the X endstop/switch? You can check it in the GUI.
Did it ever work before?
well it says it triggered i didnt think too look at that now how do i fix it
that was it i love you man
You’re welcome!
Did you fix it already?
If not: check whether it’s state changes if you manually trigger the endstop.
If it does so, you could Invert the pin state or check connection of the endstop (NC/NO).
If it does not change there is something shorted or wrongly connected/configured.
yes i fixed it when i home x now the motors spin at the moment im putting the belt back on
now y homes and sees the end stop but x is crashing
Check the cabling and proper configuration of the endstop.
im trying to use sensor less end stops
Then you have to determine the correct StallGuard threshold so it properly detects the homing impact.
yes no mater which way i go up or down it doesn’t respond
I’m only on my cell phone and can’t check your klippy.log. So please check whether all TMC drivers are declared as such and that the respective jumpers are set on the board to enable sensorless homing.
Then check again the right pin usage.
You could also check TMC dump for apparent issues and maybe swap the X and Y drivers to check whether the issue stays on the axis or moves with the driver.
i had my filament sensor plug in x end stop an its was triggered im kicking my self as i right this stupid little mistakes has had me shook now x and y are homing im working on z right now
Good if it only was such a little mistake!
And you are not the first and not the last having issues on his pah getting a working printer. :smiley:
The flawless builder shall throw the first stone!
