Printer Model: custom Cartesian
MCU / Printerboard: manta m89 +cb1
klippy (1).log (366.6 KB)
Hello all:
I have built a 310mm by 310mm by 410mm cartiesan. I am using a tr8 4 start lead screw for the bed Y-axis. This is what I have for my y axis:
Motor4
[stepper_y]
step_pin: PD3
dir_pin: PD2
enable_pin: !PD5
endstop_pin: tmc2209_stepper_y:virtual_endstop
rotation_distance: 8
position_endstop: 0
position_max: 420
position_min: -5.0
homing_speed: 100
homing_retract_dist: 0
[tmc2209 stepper_y]
uart_pin: PD4
diag_pin: PC0
run_current: 0.8
stealthchop_threshold: 999999
driver_SGTHRS: 150
when I move the axis 10 mm it only move 2 mm Edit: remeasured it moves 6mm when 25 mm requested.. Is there a way to correct this. Forgive my lack of knowledge I am to use to C and C++ / marlin firmware. I am new to python and I am still learning. Any help would be appreciated. My idea would be able to create a macro similar to some on cnc like mach 3/4 software where we could enter the desired movement input the actual movement and then it automatically calculates the necessary steps per unit.
