I have a custom-made printer, but I’ve designed the gantry to match the dimensions and belt layout of the Voron 2.0. This allows me to install a Voron Tap and Stealthburner. In my setup, the bed moves in the Z direction, not the nozzle.
Setting z_offset in the [probe] section seems to have no effect after homing. Regardless of the z_offset value, the bed is pushed up into the nozzle until the Tap optical sensor is triggered.
At that point, I manually move the bed down and run PROBE_CALIBRATE. I calibrate and get a value of -1.903, which I then save to the config.
However, if I home again, the bed is once again pushed into the nozzle until the Tap is triggered. In the Fluidd interface, I see Z reported as -1.903. If I then manually set Z to 0, the nozzle appears to be at the correct height.
Is this how it’s supposed to work? Does Z only move to 0.0 at the start of a print?
step_pin: P0.22
dir_pin: P2.11
enable_pin: !P0.21
#rotation_distance: 2.811 # 1.33 for 8 micro steps
rotation_distance: 2.515 ; 2.6 ; 3.16 # 1.33 for 8 micro steps
#endstop_pin: !P1.25
endstop_pin: probe:z_virtual_endstop # Using virtual endstop based on the probe
#position_endstop: 0.0
position_min: -2
position_max: 220
# [static_digital_input z_endstop]
# pin: P1.25
[probe]
pin: ^!P2.0 # Inductive sensor pin (replace with your actual pin)
x_offset: 0 # Adjust based on your probe's position relative to the nozzle
y_offset: 0 # Adjust as necessary
#z_offset: 0.0 # This will need to be calibrated
speed: 5.0 # Speed at which probing is done
[homing_override]
axes: xyz
set_position_x: 0
set_position_y: 0
G91 ; Relative positioning
G0 X20 Y20 ; Move XY forward by 20mm before homing
G90 ; Switch back to absolute positioning
G28 Y0
G28 X0
G0 X100 Y100
G28 Z0
#*# [probe]
#*# z_offset = -1.903
