Printer Model: MakerTech ProForge 3.5
MCU / Printerboard: BTT v2 klippy.log Where do I find this file?
pi@mainsail:~/work_directory $ cp /tmp/klippy.log .
cp: cannot stat ‘/tmp/klippy.log’: No such file or directory
The Proforge 3.5 printer is a coreXY printer with 4 Z-motors and a 300 X 300 bed..
I have poor first layer performance. I have run the Z_TILT_ADJUST routine and the Bed_Mesh routine with 9 x 9 probe points several times but I cannot get a 1st layer to stick that is bigger than 100 X 100mm.
I have run the Z_TILT_ADJUST routine several times and the the 4 probe points never are less than 250um apart in Z.
Hi, I have gone through all of the probe calibrations and tried to look for twist in the X-axis. I cannot find any problems that would cause 1mm of error in the Z-axis. Do you have any tests that would measure skew or twist?
I heated the extruders and base for 15 minutes then:
I ran Z_TILT_ADJUST 3 times in sequence and observed the Move screen data on the Printer. I watched until the second reading of the Z axis was close to 5.00mm for each location.
Location 1 2 3
Z Height 5.00 5.00 5.09
I then manually measured the Z- height at 5 positions on the base plate. I would move Z up and down until the probe would activate then record the Z-axis position.
L-F L-R R-R R-F Center
X, Y X, Y X, Y X, Y X, Y
-10, -5 -10, 230 240, 230 240, -5 110, 115
Z 1.29 2.19 1.29 0.890 0.690
Do you have any ideas as to why these Z measurements are so far off?
