Hi there,
i have a strange klipper behaviour. I cannot use
[z_tilt]
z_positions: -60, 117.5
340, 117.5
280, 117.5
speed: 300
horizontal_move_z: 3
retries: 10
retry_tolerance: 0.005
and
#*# [stepper_z]
#*# position_endstop = -0.090
together. Z=0 is always wrong when using Z_TILT_ADJUST
Babystepping/Z-Offset is adjusted via shifting the “Z-Endstop”:
which results in:
#*# [stepper_z]
MBL:
[probe]
pin: ^PC2
x_offset: -35
y_offset: 0
speed: 1
samples: 1
lift_speed: 12
[bed_mesh]
speed: 300
mesh_min: 35,10
mesh_max: 245,220
probe_count: 3,3
fade_start: 1
fade_end: 0
relative_reference_index: 4
Z Stepper:
step_pin: PA15
dir_pin: PA8
enable_pin: !PD1
microsteps: 32
rotation_distance: 4
full_steps_per_rotation: 200
endstop_pin: ^!PC0
position_min = -4
position_max: 300
homing_speed: 4
homing_retract_speed: 2
homing_retract_dist: 3
second_homing_speed: 0.5
[stepper_z1]
step_pin: PD11
dir_pin: PD10
enable_pin: !PD13
microsteps: 32
endstop_pin: ^!PA0
Hardware:
CoreXY with 2 Z motors and 2 Z endstops and 1 induktive probe for mesh bed leveling
How to reproduce the problem:
Set the
#*# [stepper_z]
to some high value, so that the nozzle will be some mm over the bed for z=0, lets say position_endstop = -3.0
Now home all axis and do a mesh bed leveling. after that go to some point of the bed. i.e center and type G0 Z0
The nozzle is about 3mm over the bed, which is correct, i have a z position endstop of -3 defined.
Now home all axis, do a Z_TILT_ADJUST and then mesh bed leveling. after that go again to some point of the bed. i.e center and type G0 Z0. Now the nozzle is attached to the bed.
It seems the the “offset” from position_endstop is ignored or not used for final z calculation. Does s.o. else encountered the same problem?
