Hello, friends! I am at a loss here. I recently got a cr10 v3 with a bad board. i replaced it with a octopus v1.1 and grabbed a [ZSYONG 2 in 1 out switching hotend. When i went to configure it, i hit a brick wall. I keep getting the error: Option ‘sync_extruder_motion’ is not valid in section ‘gcode_macro t0’
Here is a link to the relevant changes, but i do not understand how to write it out. Any help would be greatly appreciated.
klippy (1).log (50.2 KB)
Config
See docs/Config_Reference.md for a description of parameters.
OCTOPUS v1.1 CR-10 v3
For better compatibility with GCodes generated for Marlin, you
may wish to add the following section, if you have BLTouch:
[gcode_macro G29]
gcode: BED_MESH_CALIBRATE
Driver0 X
[stepper_x]
step_pin: PF13
dir_pin: PF12
enable_pin: !PF14
microsteps: 64
rotation_distance: 40
endstop_pin: PG6
position_endstop: 0
position_max: 200
homing_speed: 50
Driver1 Y
[stepper_y]
step_pin: PG0
dir_pin: PG1
enable_pin: !PF15
microsteps: 64
endstop_pin: PG9
position_endstop: 0
position_max: 200
homing_speed: 50
Driver2 Z
step_pin: PF11
dir_pin: PG3
enable_pin: !PG5
rotation_distance: 8
#position_endstop: 0.5
position_max: 200
Driver3
The Octopus only has 4 heater outputs which leaves an extra stepper
This can be used for a second Z stepper, dual_carriage, extruder co-stepper,
or other accesory such as an MMU
#step_pin: PG4
#dir_pin: PC1
#enable_pin: PA0
#endstop_pin: PG11
[stepper_z1]
step_pin: PG4
dir_pin: PC1
enable_pin: PA0
microsteps: 64
Driver4
step_pin: PF9
dir_pin: PF10
enable_pin: !PG2
microsteps: 64
rotation_distance: 33.500
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PA2 # HE0
sensor_pin: PF4 # T0
control: pid
pid_Kp: 22.2
pid_Ki: 1.08
pid_Kd: 114
min_temp: 0
max_temp: 250
[filament_motion_sensor encoder_sensor]
detection_length: 7
The minimum length of filament pulled through the sensor to trigger
a state change on the switch_pin
Default is 7 mm.
extruder: extruder
The name of the extruder section this sensor is associated with.
This parameter must be provided.
switch_pin: PG12
changing the switch_pin name according to your motherboard
pause_on_runout: True
#runout_gcode:
#insert_gcode:
#event_delay:
#pause_delay:
[extruder_stepper right]
extruder = extruder
step_pin: PC13
dir_pin: PF0
enable_pin: PF1
microsteps: 64
rotation_distance: 7.7201944 # 16 microsteps * 200 steps/rotation / steps/mm
#Correction formula is new_rotation_distance = old_rotation_distance * mmsExtracted / 100.0
detection_length: 7
Default is 7 mm.
extruder: extruder_stepper
switch_pin: PG13
#runout_gcode:
#insert_gcode:
#event_delay:
#pause_delay:
[gcode_macro T0]
gcode =
#G1 E-50 F900
#Disable right stepper
SYNC_EXTRUDER_MOTION: EXTRUDER=right MOTION_QUEUE=
#Enable main left stepper
SYNC_EXTRUDER_MOTION: EXTRUDER=extruder MOTION_QUEUE=extruder
#G1 E50 F900
[gcode_macro T1]
gcode =
#G1 E-50 F900
#Disable main left stepper
SYNC_EXTRUDER_MOTION EXTRUDER=extruder MOTION_QUEUE=
#Enable right_stepper
SYNC_EXTRUDER_MOTION EXTRUDER=right MOTION_QUEUE=extruder
#G1 E50 F900
[gcode_macro TOOLCHANGE_RETRACT]
gcode: G91 G1 E-5 F1500 G1 E-65 F800
#Relative Coordinates
#G91
#Quick 5mm Retract
#G1 E-5 F1500
#Retract 100mm and lift Z 5mm for toolchange
#G1 E-65 F800
#SET_EXTRUDER_ROTATION_DISTANCE
#SYNC_EXTRUDER_MOTION
#extruder_stepper
#macro changes SYNC_EXTRUDER_MOTION
[heater_bed]
heater_pin: PA1
sensor_pin: PF3 # TB
control: pid
#Stock PID configuration taken from Marlin
pid_Kp: 201.86
pid_Ki: 10.67
pid_Kd: 954.96
min_temp: 0
max_temp: 130
[fan]
pin: PH6 #ar9
serial: /dev/ttyUSB0
[printer]
kinematics: cartesian
max_velocity: 300
max_accel: 3000
max_z_velocity: 5
max_z_accel: 100
#Uncomment the following lines if you have a BL-Touch
[bltouch]
sensor_pin: PB7
control_pin: PB6
set_output_mode: 5V
pin_move_time: 0.4
stow_on_each_sample: False
probe_with_touch_mode: False
x_offset: 45.75
y_offset: -3.40
z_offset: 3.28
samples: 2
sample_retract_dist: 2
samples_result: average
[bed_mesh]
speed: 50
horizontal_move_z: 6
mesh_min: 46.50,0.75
mesh_max: 253.5,295.85
probe_count: 7,7
algorithm: bicubic
[pause_resume]
recover_velocity: 50
[filament_switch_sensor fil_runout_sensor]
switch_pin: PG12
[bed_screws]
screw1: 33,29
screw1_name: front left screw
screw2: 273,29
screw2_name: front right screw
screw3: 273,269
screw3_name: rear right screw
screw4: 33,269
screw4_name: rear right screw
TMC2209 configuration
#[tmc2209 extruder2]
#uart_pin: PE1
#run_current: 0.800
#stealthchop_threshold: 999999
#[tmc2209 extruder3]
#uart_pin: PD3
#run_current: 0.800
#[screws_tilt_adjust]
#screw1: 0,29
#screw1_name: front left screw
#screw2: 228,29
#screw2_name: front right screw
#screw3: 228,269
#screw3_name: rear right screw
#screw4: 0,269
#screw4_name: rear right screw
#speed: 50
#horizontal_move_z: 10
#screw_thread: CW-M3
Macros
[delayed_gcode activate_default_extruder]
initial_duration: 1
ACTIVATE_EXTRUDER EXTRUDER=extruder
[gcode_macro T0]
# Deactivate stepper in my_extruder_stepper
SYNC_EXTRUDER_MOTION EXTRUDER=belted_extruder MOTION_QUEUE=
# Activate stepper in extruder
SYNC_EXTRUDER_MOTION EXTRUDER=extruder MOTION_QUEUE=extruder
#SET_PRESSURE_ADVANCE ADVANCE=0 EXTRUDER=extruder
[gcode_macro T1]
# Deactivate stepper in extruder
# Activate stepper in my_extruder_stepper
SYNC_EXTRUDER_MOTION EXTRUDER=belted_extruder MOTION_QUEUE=extruder
SET_PRESSURE_ADVANCE ADVANCE=0 EXTRUDER=belted_extruder
[board_pins]
aliases:
# EXP1 header
EXP1_1=PE8, EXP1_2=PE7,
EXP1_3=PE9, EXP1_4=PE10,
EXP1_5=PE12, EXP1_6=PE13, # Slot in the socket on this side
EXP1_7=PE14, EXP1_8=PE15,
EXP1_9=, EXP1_10=<5V>,
# EXP2 header
EXP2_1=PA6, EXP2_2=PA5,
EXP2_3=PB1, EXP2_4=PA4,
EXP2_5=PB2, EXP2_6=PA7, # Slot in the socket on this side
EXP2_7=PC15, EXP2_8=<RST>,
EXP2_9=<GND>, EXP2_10=PC5
