ADXL345 inputshaper not working
Printer Model: Sapphire Pro
MCU / Printerboard: Raspberry Pi 4B, stock Sapphire Pro Mainboard
Hello :slight_smile:
I am really getting desperate with the setup of inputshaper.
I tried to set it up last week without any luck. Did I miss anything? Thank you for your help!
Hardware: Raspberry Pi 4B with klipperscreen, ADXL345, Sapphire Pro with 2 month old klipper install,
Problem:
As soon as I add the code from the manual klipper does not start anymore.
Error in the dashboard:
MCU 'rpi' error during config: Unable to open spi device
Error configuring printer
What did I do:
I followed the video from Nero 3D
Guide from klipper Measuring_Resonances + RPi_microcontroller
My ADXL345 looks like the picture on the right and connected it like that, I swapped 100cm cables with 20cm jumper cables as a test.
SPI is active.
systemctl status klipper-mcu is active.
Folder exists lrwxrwxrwx 1 root root 10 Sep 17 12:13 klipper_host_mcu -> /dev/pts/0
Second ADXL345 sensor tested without luck.
I tried pretty much everything I could find. SD card backed up and copied to new SD card and tested other Pi 4B.
Some thougts:
Could klipper screen/drivers cause problems for the GPIO Pins and adxl345?
Is there a problem with my printer.cfg?
Is klipper damaged? I did not install much. Only klipperscreen with driver, obico and mobileraker.
klippy.log (1.7 MB)
Run
grep spi /boot/config.txt
and
ls /dev/spi*
Copy and paste output here
Thank you :slight_smile:
pi@klipper:~ $ grep spi /boot/config.txt
dtparam=spi=on
dtparam=spi=on
pi@klipper:~ $ ls /dev/spi*
ls: cannot access โ€˜/dev/spi*โ€™: No such file or directory
Try adding
dtoverlay=spi0-cs
to the /boot/config.txt file, then reboot
Thank you, now I am a step further :slight_smile:
Had to uncommentdtoverlay=mhs395:rotate=90
I dont know from what that exactly is. Maybe Screen?
With dtoverlay=spi0-cs it now starts and works after 2 reboots. I dont know why I needed 2 but after the first I did not get any values of the sensor.
