My Anycubic i3 MegaS was printing A OK, useable before klipper installed, but after that every time I need to print, I need to manually turn the flow on Fluidd to 200%, or set 200% flow in Gcode and still need to turn 125~150% of flow on Fluidd. otherwise the PLA won’t stick on the hot bed, and I did tried to put tapes on the hot bed and the 200% flow is still required. And even tho, the print is still weak and fragile it break even when I try to pull it out from hot bed.
Please share your klippy.log file. Potentially your extruder rotation_distance is off.
printer (3).cfg (5.3 KB)
klippy-2 (1).log (3.4 MB)
I changed my settings but now all the prints are drifting even those Gcodes that was printing normally
I solved it! reduce the value of acceleration in [printer] and it works smoothly now.
