Is anyone else experiencing an issue where Arc commands reverse the direction of the extruder? I have a start_print macro setup that looks like this:
[gcode_macro START_PRINT]
{% set EXTRUDER_TEMP = params.EXTRUDER_TEMP|default(220)|float %}
# Use absolute coordinates
G90
M82
# Start bed heating
M140 S{BED_TEMP}
# Start nozzle heating
M104 S{EXTRUDER_TEMP}
# Home the printer
G28
# Reset the G-Code Z offset (adjust Z offset if needed)
#SET_GCODE_OFFSET Z=0
#Set bed mesh profile
BED_MESH_PROFILE LOAD=default
#Wait for bed and nozzle heating
M190 S{BED_TEMP}
M109 S{EXTRUDER_TEMP}
G1 X-126 Y0 Z0.4 F3000
# Extrude about 40 mm by printing a 90 degree arc
G3 X0 Y-126 I126 E40 F2700
# Retract and move nozzle up
G92 E0
G1 E-1.5 F1800
G0 Z0.5
G1 E0 F300
The line that causes the issue is: G3 X0 Y-126 I126 E40 F2700.
Looking at the Klipper documentation it says the I and J parameters go at the end. I changed the line so that it is now: G3 X0 Y-126 E40 F2700 I126 and the issue hasn’t happened since. However, looking at all the arc_welder generated code, it does not follow this format with I and J parameters at the end, and I am afraid this issue is happening during my prints. Anyone else experiencing an issue? Any ideas what is going on? Does the order of parameters really matter?
