Printer Model: Anycubic Kobra 2 Neo
Host / SBC: Raspberry Pi 3B
Current Config That I’m Using:
# ORIGINAL CONFIGS BY j0tp3
# MODIFIED AND GENERALLY IMPROVED BY zamonary1
# v0.7.3.5
# kvgx12 was very first to figure out how to flash the firmware
# Input shaper frequencies was provided by xenyon
# stop macro was taken from jschuh's github repo, pause and resume currently doesn't work but i am working on it
# Also you can look at other people, without whom it would be impossible to do this at our discussion (linked below)
# Thank you all guys for making this happen and thank YOU for your interest in our work.
# For suggections or improvements contact me via discord or telegram @zamonary1 or via our discourse thread
# https://klipper.discourse.group/t/getting-orange-pi-3-lts-klipper-working-with-anycubic-kobra-2-neo
# Links to all of those cool guys mentioned above (except me ;_;)
# https://klipper.discourse.group/u/kvgx12/
# https://klipper.discourse.group/u/j0tp3/
# https://klipper.discourse.group/u/xenyon/
# https://klipper.discourse.group/u/kuroi/
# https://github.com/jschuh/klipper-macros/
# Please, do not remove this sign, these configs are distributed free of charge anyways :)
# [include moonraker_obico_macros.cfg]
[include mainsail.cfg]
[include pause_resume.cfg]
[include scripts.cfg]
#[include display.cfg]
[exclude_object]
[gcode_arcs]
restart_method: command
baud: 250000
[printer]
kinematics: cartesian
max_velocity: 250
max_accel: 3000
max_z_velocity: 8
max_z_accel: 800
[virtual_sdcard]
path: ~/printer_data/gcodes
on_error_gcode: CANCEL_PRINT
[input_shaper]
shaper_type_x : mzv
shaper_freq_x : 65.200000
shaper_type_y : 2hump_ei
shaper_freq_y : 61.200000
[stepper_x]
step_pin: PA12
dir_pin: PA11
enable_pin: !PA15
rotation_distance: 40
endstop_pin: ^!PB11
position_endstop: -10
position_min: -14
position_max: 225
homing_speed: 60
[stepper_y]
step_pin: PA9
dir_pin: !PA8
enable_pin: !PA15
endstop_pin: ^!PC13
position_endstop: -2
position_min: -3
position_max: 240
homing_speed: 60
step_pin: PB0
dir_pin: !PB1
enable_pin: !PA15
rotation_distance: 8
position_min: -2
position_max: 200
homing_speed: 8
second_homing_speed: 2
max_extrude_cross_section: 5.0
step_pin: PB15
dir_pin: PB14
enable_pin: !PA15
max_extrude_only_distance: 200
max_extrude_only_velocity: 80
max_extrude_only_accel: 2500
rotation_distance: 7.084
nozzle_diameter: 0.400
filament_diameter: 1.750
pressure_advance: 0.06
heater_pin: PB8
sensor_pin: PC3
min_extrude_temp: 190
min_temp: 0
max_temp: 250
control: pid
#pid_kp: 14.42
#pid_ki: 0.88
#pid_kd: 59.12 # old values
pid_Kp=20.861
pid_Ki=1.095
pid_Kd=99.353
pressure_advance: 0.225 # needs more testing, i am open for suggestions
[heater_bed]
heater_pin: PB9
sensor_pin: PC1
min_temp: 0
max_temp: 120
control: pid
#pid_kp: 97.1
#pid_ki: 1.41
#pid_kd: 1675.16 # old values
pid_Kp=59.418
pid_Ki=1.082
pid_Kd=815.506
[probe]
pin: PA1
x_offset : 24.0
y_offset : 13.35
#z_offset: 0
samples: 3
samples_result: average
sample_retract_dist: 1
speed: 3
lift_speed: 8
samples_tolerance : 0.1
samples_tolerance_retries : 3
[bed_mesh]
speed: 200
horizontal_move_z: 3
#mesh_min: -8, 0
mesh_min: 14, 11
mesh_max: 210, 215
probe_count: 6,6
mesh_pps: 5,5 #interpolation, not the actual probe count
algorithm: bicubic
bicubic_tension: 0.2
[safe_z_home]
home_xy_position: 5, 5
speed: 60
z_hop: 4
z_hop_speed: 9
[firmware_retraction]
retract_length: 1.8
retract_speed: 50
#unretract_extra_length: 0
unretract_speed: 50
[controller_fan controller_fan]
pin: PB12
[heater_fan extruder_fan]
pin: PB13
[fan]
pin: PB5
cycle_time: 0.00005 #20kHz
#This pin enables the bed, hotend, extruder fan, part fan.
[output_pin enable_pin]
pin: PB6
value: 1
#*# [probe]
#*# z_offset = 0
Hi all, I successfully installed Klipper on my Anycubic Kobra 2 Neo, and the first few prints went really well. However, every time I change the nozzle size (from 0.4 to 0.2 or 0.6), I have to manually recalibrate the Z offset. The K2N has a Z stop button that can calculate the Z offset via auto leveling. How can I set up Klipper to use the existing hardware for auto leveling?
Thanks for your help!
