Kobra 2 neo config file (tested and run 24/7 for over a month now)
Here is my very thouroughly tested config file for the kobra 2 neo with the best input shaper reults averaged from 3 machines; viel spass damit!
#Configuration file for the Anycubic Kobra 2 neo. (Trigorilla 4.0.1 Board)
#please read every comment before changing and using this config to ensure you dont break anything.
#DISCLAIMER
#This Printer config was written and optimized by and with the help of the Klipper forum group.
#THIS IS NO LONGER AS EXPERIMENTAL but still nobody will give you any warranty in case your printer blows up. (which it probably wont)
#version 2.0.1
#tested on 3 printers - fixed errors - generalized file paths - works now.
#please excuse any spelling or grammatical errors in my comments as english is not my native.
#comments by xenyonmedia and mysterious cable (reddit only)
#Included files
[include mainsail.cfg]
[include makro.cfg] 	#comment this if you dont have this macro file.
#[include adxl.cfg] #uncomment this if you want to connect an adxl sensor and have this config file
#mcu config (i would advise against changing this besides from the serial)
serial:/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0 #set this to your serial connection after running ls /dev/serial/by-id/*
baud: 115200
restart_method: command
#printer config
[printer]
kinematics: cartesian
max_velocity: 250 #you can increase this, but stealthchop will vibrate the belts violently if moving faster!!!
max_accel: 10000 #yes it does 10k atlease at 250mm/s
max_z_velocity: 8 #dont change this
max_z_accel: 800
#this is my input shaper result, change or disable this only if you know what it does and at best have an adxl sensor
[input_shaper]
shaper_freq_x: 54.8
shaper_type_x: ei
shaper_freq_y: 34.0
shaper_type_y: mzv
#virtual SD
[virtual_sdcard]
path: ~/printer_data/gcodes
on_error_gcode: CANCEL_PRINT
#x stepper
[stepper_x]
step_pin: PA12
dir_pin: PA11
enable_pin: !PA15
rotation_distance: 40
endstop_pin: ^!PB11
position_endstop: -10
position_min: -14
position_max: 220
homing_speed: 100 #this sets the homing speed.
#y stepper
[stepper_y]
step_pin: PA9
dir_pin: !PA8
enable_pin: !PA15
endstop_pin: ^!PC13
position_endstop: -2
position_min: -3
position_max: 230
#z stepper
step_pin: PB0
dir_pin: !PB1
enable_pin: !PA15
rotation_distance: 8
position_min: -2
position_max: 200
homing_speed: 15
second_homing_speed: 2
#extruder config
max_extrude_cross_section: 5.0 #change if you change nozzle diameter to something large
step_pin: PB15
dir_pin: PB14
enable_pin: !PA15
max_extrude_only_distance: 200
max_extrude_only_velocity: 80
max_extrude_only_accel: 5000
rotation_distance: 7.084
nozzle_diameter: 0.400
filament_diameter: 1.750
pressure_advance: 0.06 #if you see bulges or underextrusion on corners, tune this with the documentation (https://www.klipper3d.org/Pressure_Advance.html)
heater_pin: PB8
sensor_pin: PC3
min_extrude_temp: 190
min_temp: 0
max_temp: 250
control: pid
pid_ki: 0.88
pid_kd: 59.12
#pressure advance
pid_kp: 14.42 #tune this with this guide (https://www.obico.io/blog/klipper-pid-tuning/)
#hotbed
[heater_bed]
heater_pin: PB9
sensor_pin: PC1
min_temp: 0
max_temp: 120
control: pid
pid_kp: 97.1 #tune this with this guide (https://www.obico.io/blog/klipper-pid-tuning/)
pid_ki: 1.41
pid_kd: 1675.16
#inductive probe settings
[probe]
pin: PA1
x_offset : 24.0
y_offset : 13.35
#z_offset: 0
samples: 3
samples_result: average
samples_tolerance_retries: 1
sample_retract_dist: 2
speed: 15
lift_speed: 8
samples_tolerance : 0.1
samples_tolerance_retries : 3
#auto bed level settings
[bed_mesh]
speed: 200
horizontal_move_z: 3
mesh_min: 14, 11
mesh_max: 210, 215
probe_count: 7,7 #change this if you want more or less probe points
mesh_pps: 4,4
algorithm: bicubic
bicubic_tension: 0.2
#zhome probing. Probably dont change this
[safe_z_home]
home_xy_position: 110, 110
speed: 100
z_hop: 10
z_hop_speed: 15
[controller_fan controller_fan]
pin: PB12
[heater_fan extruder_fan]
pin: PB13
[fan]
pin: PB5
cycle_time: 0.00005 #20kHz
#This pin enables the bed, hotend, extruder fan, part fan.
[output_pin enable_pin]
pin: PB6
static_value: 1
#*# [probe]
#*# z_offset = 1.595
#*# [bed_mesh default]
#*# version = 1
#*# points =
#*# 	-0.003333, 0.034167, 0.032500, 0.094167, 0.156667
#*# 	0.075000, 0.080833, 0.062500, 0.093333, 0.117500
#*# 	0.065000, 0.047500, -0.004167, 0.008333, -0.002500
#*# 	-0.062500, -0.088333, -0.134167, -0.132500, -0.167500
#*# 	-0.146667, -0.211667, -0.298333, -0.364167, -0.408333
#*# x_count = 5
#*# y_count = 5
#*# mesh_x_pps = 4
#*# mesh_y_pps = 4
#*# algo = bicubic
#*# tension = 0.2
#*# min_x = 14.0
#*# max_x = 210.0
#*# min_y = 11.0
#*# max_y = 215.0
where can I find the settings for building the firmware for this board?
Welcome shtirlitz,
I don’t know this printer, but since nobody answers I’ll do.
You could try the printer.cfg from above. A quick www search gave me Klipper (MOD) - Kobra2Neo Insights
There should be everything you need to install Klipper.
Good luck, hcet14
I just installed klipper and mainsail. This working great so far! Thanks for the awesome config
