Automatic deletion of Printer.cfg
Thank you @DaVinci10
I am communicating with you through translation as I do not speak English very well, so I think there might be some issues with communication. My issue is as follows:
When there is an update in Klipper, there is a problem with the printer.cfg file. It also warns me before making the update. However, this issue does not always occur. Because of this, I am receiving the following error message:
“mcu ‘mcu’: Unable to connect. Once the underlying issue is corrected, use the ‘FIRMWARE_RESTART’ command to reset the firmware, reload the config, and restart the host software. Error configuring printer.”
