hello. n4 max openneptune. x axis perfectly parallel to base. bed is warped on y axis. when i try axis twist comp (atc) with paper method then save then bed mesh, mesh is still same. is it normal? shouldnt i see the bed mesh according to atc? in printer.cfg atc’s measurements are at the end of the page. i know that paper method is not the best way but it has to change the mesh even a little. and the top side’s z offset and deep area z offset’s are very different when i do paper method.
screw tilt adjust and full bed mesh yes. but i realized that if i try to catch same z offsel during atc it doesnt work. if i make it depend on bed mesh i mean much lower where that hill or mush higher where the hollow it works. is it normal?
bed is leveled with screw tilt calc. im sure x axes are parallel to base.
for neptune 4 max, maybe more than 5 sample is unnecesarry but im just trying different solutions..
