Printer Model: Ender3v3 SE
MCU / Printerboard: 4.2.7
Host / SBC BTTPad 7
After the axis twist comp it does a good job at helping level the bed, but the back right corner is significantly off. my probe is mounted on the front left of my print head, ender 3v3SE. I have the x,y min and max set to the furthest it can go on the bed, but it cant reach that corner.
Is there a way to compensate for this? I did not see anything in the docs about it. Can i manually add a value in the printer.cfg or anything?
[axis_twist_compensation]
#speed: 50
# The speed (in mm/s) of non-probing moves during the calibration.
# The default is 50.
#horizontal_move_z: 5
# The height (in mm) that the head should be commanded to move to
# just prior to starting a probe operation. The default is 5.
calibrate_start_x: 10
# Defines the minimum X coordinate of the calibration
# This should be the X coordinate that positions the nozzle at the starting
# calibration position.
calibrate_end_x: 199
# Defines the maximum X coordinate of the calibration
# This should be the X coordinate that positions the nozzle at the ending
calibrate_y: 123
# Defines the Y coordinate of the calibration
# This should be the Y coordinate that positions the nozzle during the
# calibration process. This parameter is recommended to
# be near the center of the bed
# For Y-axis twist compensation, specify the following parameters:
calibrate_start_y: 10
# Defines the minimum Y coordinate of the calibration
# This should be the Y coordinate that positions the nozzle at the starting
# calibration position for the Y axis. This parameter must be provided if
# compensating for Y axis twist.
calibrate_end_y: 215
# Defines the maximum Y coordinate of the calibration
# This should be the Y coordinate that positions the nozzle at the ending
calibrate_x: 134
# Defines the X coordinate of the calibration for Y axis twist compensation
# This should be the X coordinate that positions the nozzle during the
# calibration process for Y axis twist compensation. This parameter must be
# provided and is recommended to be near the center of the bed.`Preformatted text`
