Printer Model: Ender 5 Pro
MCU / Printerboard: BTT SKR mini E3 V3 with BIQU microprobe v2
I’m trying to get my bed to home on the Z axis, but it doesn’T work. The printer head centers above the bed, the bed lowers a few milimeters, and then I get this error message in the console window: Endstop z still triggered after retract.
I can get the probe to deploy/retract using the mcros on the dashboard in Mainsail. Tried using the Z endstop connection as well as different pin definitions, but I’m stuck.
Any help very appreciated!
klippy (1).log (322.0 KB)
Hello @Oblikfan !
You may have a probe installed, but the Z-axes still uns on endstop:
step_pin = PB0
dir_pin = !PC5
enable_pin = !PB1
microsteps = 16
rotation_distance = 8
endstop_pin = ^PC2 # <---------
position_endstop = 0.0
position_max = 250
Using a probe as endstop works a different way:
https://www.klipper3d.org/Config_Reference.html?h=probe#probe
Thank for the reply.
reading the configuration reference file, I can’t figure out what pin to use for my endstop. If I try unsing one of the pins for the probe, I get an error message saying the pin is used twice in the .cfg file
It’s not a pin on the board:
The probe section also creates a virtual “probe:z_virtual_endstop” pin.
Ok, the virtual pin is setup and the bed tries to home, but it won’t stop when it reaches the probe.
Please attach a recent klippy.log to your next post.
Figured it out, the probe was sitting too high compared to my hotend nozzle.
Moved it down and now it homes ok.
