BLTOUCH failed to raise probe
Printer Model: Two Trees SP-5
MCU / Printerboard: MKS Robin Nano v1.2
Host / SBC: Mainsail with Raspberry Pi 4
klippy.log klippy.zip (952.9 KB)
I have been using my printer today and I adjusted baby stepping then SAVE_CONFIG. Now, my printer will not complete a G28 Home.
When I command G28, the printer will move the Z axis down 10mm, then home X and Y, but will not drive the Z axis to the BLTOUCH probe.
I can force_move the Z axis up and down.
Any ideas why G28 will not drive the Z axis to the BLTOUCH probe?
Is it a genuine BLtouch or some clone?
You may have a look on this:
https://www.klipper3d.org/BLTouch.html
I have been using a genuine BLtouch probe on this printer with Klipper for about a year.
The problem occurred after baby stepping z-offset then issuing a SAVE_CONFIG command.
I found the BLtouch connector was not seated. I reconnected the connector and now the printer will perform a G28 HOME.
Thank you.
