Printer Model: Kobra 2
MCU / Printerboard:Trigorilla_Pro V1.0.2
Host / SBC PI4
After klippy (2).log (2.1 MB)
Before klippy.log (4.3 MB)
…Both heaters stopped working on Sunday I have upgraded & downgraded Klipper. Reinstalled klipper . Not hardware issue as I tried marlin both heat. Don’t know what to do. Please help
Hello @Poppy45 !
This:
Stats 287.1: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000006 mcu_task_stddev=0.000005 bytes_write=1256 bytes_read=6169 bytes_retransmit=0 bytes_invalid=0 send_seq=133 receive_seq=133 retransmit_seq=0 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=167995347 sd_pos=43811 heater_bed: target=60 temp=18.1 pwm=1.000 sysload=0.23 cputime=6.566 memavail=3598256 print_time=29.893 buffer_time=0.000 print_stall=0 extruder: target=200 temp=19.0 pwm=1.000
Stats 288.1: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000006 mcu_task_stddev=0.000005 bytes_write=1262 bytes_read=6288 bytes_retransmit=0 bytes_invalid=0 send_seq=134 receive_seq=134 retransmit_seq=0 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=167995386 sd_pos=43811 heater_bed: target=60 temp=18.1 pwm=1.000 sysload=0.23 cputime=6.581 memavail=3601280 print_time=30.894 buffer_time=0.000 print_stall=0 extruder: target=200 temp=18.9 pwm=1.000
Heater extruder no longer approaching target 200.000
Stats 289.1: gcodein=0 mcu: mcu_awake=0.001 mcu_task_avg=0.000006 mcu_task_stddev=0.000005 bytes_write=1268 bytes_read=6409 bytes_retransmit=0 bytes_invalid=0 send_seq=135 receive_seq=135 retransmit_seq=0 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 upcoming_bytes=0 freq=167995425 sd_pos=43811 heater_bed: target=60 temp=18.2 pwm=1.000 sysload=0.23 cputime=6.600 memavail=3601040 print_time=31.896 buffer_time=0.000 print_stall=0 extruder: target=200 temp=18.9 pwm=1.000
Transition to shutdown state: Heater extruder not heating at expected rate
See the 'verify_heater' section in docs/Config_Reference.md
is to 99.99% a hardware issue.
When the extruder is is set to 200°C and the PWM is at 100% but the temperature stays at 18.9°C. there is a hardware issue.
You may triple check the wiring, the output of the printer board, the PSU etc.
Hi been there done that . Both will heat in marlin software so that’s why i think it is something else. All movement works Thanks
Solved This board you need a value on Output pin section then the heaters work. they worked before with a static value which i removed.
[output_pin power_ctrl]
pin: PB4
value: 1
