Printer Model: Ender 5 plus used to build real printer
MCU / Printerboard:btt octopus pro v1.1
Host / SBC banana-pi m5
klippy.log klippy.log (192.3 KB)
Fill out above information andin all cases attach yourklippy.logfile (use zip to compress it, if too big). Be sure to check our “Knowledge Base” Category first. Most relevant items, e.g. error messages, are covered there
using fan5 output with psu jumper removed and grounded, so I’ve a ground switched output to drive a motor controller. But output swing is only a few millivolts, like 4 or 5. What do I do to get at least a 3.8 volt swing from PD15 ?? Also, the swing I do see on the scope is upside down. So where can I get a logic swing, and right side up?? I need a pwm output where on time is positive.
@NAPCAL indicated that you need a pull up resistor but that will be a problem with a motor.
You need to supply a positive voltage which has a common ground with the Octobpus Pro BUT motor current will have to in the range of a fan, which is usually 300-500mA.
If you’re going to control a motor that requires more than 500mA of current then you’re probably going to need to use something other than a fan driver on the board.
Sorry mike, I thought I had made that clear, yes, there is a motor controller, one big enough to replace the trigger in a hammer drill. 50-150 amps at 40 volts, needs 3.5 volts or more from the octopus pro. First one I tried looks like enough but had 0 volts at the 12 volt terminal, which meant there was no voltage to the driver chip, ordered another, got it yesterday and its 12 volts is good but then I finally twigged that the drive from the pro boards PD15 was upside down, not to mention pretty noisy on the other end of 3 feet of plain wire. So I ordered 5 optocoupler kits, one of which will filter the 60 mhz junk, and invert the needed sigs. Ought to get them later tomorrow. That and my insurance got pissy about my meds so I’ve been puttering around with sugar readings in the 300’s for a week+, scared to eat etc. Fixed that and feel better now, more like the 90 yo I am. When I get this working, do you all want to see schematics? I’ve noted that a pix pile on this machine was quickly deleted 3 or 4 months back. So until then, take care of #1.
got the opto stuff, had to use two in series, 2nd to invert, so while I haven’t moved the motor yet, still need to figure out the 3 control pins I am NOT driving. Scope pix of finished opto’s output to the driver.
I’m awake again, left that setup running overnight to see if anything got hot, didn’t. Now. is there anyone who has used this board recognizes it, and knows how to make it behave, can advise me what to do with the 5 pins at lower front for input, I’d sure appreciate it. In the meantime, I’ll have a play at it. and will report if I succeed.
Well, mykepredco, it didn’t take long and I have learned (a)there must be a flea clip on the right two pins to enable it, and (b) the low voltage of the off time of 2.15 volts is still a logic 1 to the controller, and (c) both the start and the stop are absolutely brutal, the motor jumped clear off the table. So I need to lower that voltage drive. A 150k R wired in series with the opto vcc fixed the negative swing. So I’ve now destroyed 2 of that driver, so I’m about to let my imagination out to play w/o a chaperone. The target now is to integrate that pulse with an rc circuit, and use that analog voltage to modulate the current available from a 300 watt 40 volt buck supply to ramp the motor current up and down slowly, say 2 secs to 20 amps, then when its job is done, let it essentially coast under a current ramped back down to whatever the minimum limit can be set to. Let it idle at that minimum current while the voltage is ramping back to minimum current with a comparator eventually opening the teeny power switch. Since the buck thingy is on Black Friday sale, 4 of them @ at a $21 bill sounds like a good deal. Be here Wednesday. I’ll post how that works if and when its working. Thanks for listening. Take care of #1. Gene1934, aka WOWElctronics.
