BTT HDMI 7 screen
Hi all,
Apologies if this has been covered before. New HDMI 7" display from BTT - has anyone managed to get it to work with KlipperScreen on PI4? I have connected and modified boot.txt as per BTT pdf manual :
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=87
hdmi_cvt 1024 600 60 6 0 0 0
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
hdmi_drive=1
I started to get console on boot but garbage instead of KlipperScreen.
Figured out that may be because I have set my PI up for “stock” PI screen before, and disabled dtoverlay:
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
# dtoverlay=vc4-fkms-v3d # Disabled now
max_framebuffers=2
Now I have the KlipperScreen screen but it does not fit the display (like 2 time larger than it should. Any help is much appreciated.
TIA
Put an = before 1024. I don’t know that that’s the issue, but that brings it in line with the other settings. I got my 5” display working last night using similar settings.
Thanks, tried that (= was missing from BTT manual)… still does not work. It looks like this screen just does not want to go to 1024x600 mode. I have tried to use hdmi force mode and the screen just hangs with the rainbow.
This is my /boot/contig.txt that works with 7" Touchscreen and Pi3B I did not delete the uncommented lines to make it easier to compare…
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
[pi4]
max_framebuffers=2
[all]
#dtoverlay=vc4-fkms-v3d
# enable raspicam
start_x=1
gpu_mem=128
overscan_scale=1
hdmi_force_edid_audio=1
dtparam=i2c_arm=on
dtparam=spi=on
enable_uart=1
display_rotate=0
max_usb_current=1
config_hdmi_boost=7
hdmi_group=2
hdmi_mode=87
hdmi_drive=2
Thanks, I since discovered that it works with Bullseye build of RasPI Linux but not with Buster based image.
I got the same problem myself: I moved klipper from a RasPi3B to a small PC (i3) i bought at *Bay for 65€ (I have to controle 2 printers and RasPi is too expensive today). But Klipperscreen is not working since I installed Ubuntu server 20 and I am a linux rookie and (so far) not able to get this 1024x600Px screen running but I will keep on trying… Meanwhile I use the “old” installation of KlipperScreen on the Pi with the PC, that works nicely. I made a housing for it: Raspberry 3b 7 inch Touchscreen cover by BergKaese - Thingiverse
Some days lator I got it running. Had some X-Issues that I solved and now I switched of my raspi and connect the 7" directely to the HDMI of my I3…
I was able to get mine working on buster with the following in the config.txt
#uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=87
hdmi_cvt=1024 600 60 6 0 0 0
#uncomment to force a HDMI mode rather than DVI. This can make audio work in DMT (computer monitor) modes
#hdmi_drive=1
#hdmi_force_edid_audio=1
max_usb_current=1
config_hdmi_boost=10
[pi4]
#Enable DRM VC4 V3D driver on top of the dispmanx display stack
max_framebuffers=2
I am not using the BigTreeTech HDMI7 for Klipper, but as a display for a Raspberry pi 5 with desktop. I was having an issue where the screen stayed black, and what I found is that the BigTreeTech documentation does not provide the right code to enter (it is missing the = sign between “hdmi_cvt” and “1024” (4th line). The correct code to add to the config.txt is:
hdmi_group=2
hdmi_mode=87
hdmi_drive=1# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=87
hdmi_drive=1
I hope this helps anyone having issues with this BTT HDMI 7 display.
