The flashing of the LEDs (status LEDs for the heater outputs) are normal, because PID regulates the temperature by PWM.
The clicking can occur due to the high current impulses. Do you have a magnetic bed plate on the printer? Sometimes thy make that “noise” because the heater coil on the bed also works as a electric magnet.
I just started a print on same objekt but sliced with Simplyfied 3D.
At the moment it just prints!
No issue regarding the hotend temp!?
Will add the Klipper log after print is ready
I will check up an other version of Prusa slicer to see if it lays on the slicer.
I will let you know of the outcome.
Did a new test to find out the “ticking” sound when starting the extruder.
Everything is fine until it reaches 170-180C then it starts “ticking”.
I was told that it maybe could have something to do with my magnetic heatbed but it could not be. I disconneted the heatbed and still same issue.
I attach a small vidoe on the issue. Turn up your volume to hear the “ticking”
