BTT Manta M8P Extruder
Geeetech A20
M8p+CB1
Hi all
Phil here, noob with Klipper
i have purchased a BTTManta M8P to replace the failing stock board.
i have had “fun” working out how to install and configure Klipper, and working my way through all the challenges that that threw up.
So far i have the bed and nozzle heaters working, x and y on sensor less homing. Z controlled by a BLTouch.
Z offset configured. everything finally coming together, all bar the extruder!!!
if i run stepper_buzz on x, y and z i get the expected oscillation. absolutely nothing.
for fault finding i swapped the cable for x and the extruder.
re running the stepper_buzz i now have the extruder oscillating but x is stagnant.
stepper driver i hear you say, i then swapped the driver for x and the extruder. extruder, plugged into x oscillates but x, in the extruder port will not.
all i can see left is the config…
i have searched and read every thing i can find regarding the correct pin assignment and it looks like there may be an issue with motor 6,7 and 8 but they all state the same config for motor 5
is there anyone out there that could possibly shed some light as to where to look next be fore i pull my remaining hair out!!!
i have tried on other motor ports but to no avail
thanks in advance
Phil
klippy (8).log (687.5 KB)
[stepper_z1]
step_pin = !PD3
dir_pin = PD2
enable_pin = PD5
microsteps = 16
rotation_distance = 8
Change the enable pin to !PD5.
Hi jakep_82
thanks for that,
have made the change, still no extruder!!??
Please post a new log.
klippy (9).log (1.2 MB)
sending again
@jakep_82 asked you to change this line:
[stepper_z1]
enable_pin = PD5
to
[stepper_z1]
enable_pin = !PD5
If the extruder does not work, try this:
enable_pin = PD1
to
enable_pin = !PD1
BTW @jakep_82 : Please use code braces when you post code:
Format
@PhilG
What version is your M8P?
The stepper pins for M6 - M8 are different between the two versions.
Is the cable plugged into the 4th or 5th connection on the Manta board? it has the 3rd and 4th running in parallel.
Hi guys
I run 2 z axis motors. 1 to4 look after motion and using 5 for the extruder.
@NAPCAL … my saviour.
Now have extruder in motor8 configured to v1.1.
Still getting driver errors. The 2209 is now in standalone mode I can extrude molten plastic​:+1::grinning::innocent:
The next hurdle is getting my head around macros. Configuration and calibration.
Thanx everyone for the advice
:wink:
