Klipper ender 3v2
klippy (9).log (1.5 MB)
… Hello everyone,
I’m having an issue with my Ender3 v2 (board 4.2.7) running Klipper. My extruder motor doesn’t turn when I issue the command G1 E10 F300 now with move extruder – the motor remains stationary. I’ve checked my wiring and connections, and everything seems to be in order.Also checked drivers they also seems to be oke Vref are as they need to be. Also tried !PB4 for dir pin but nothing. Extruder section in printer.cfg (using step_pin PB3, dir_pin PB4 & i tried with !PB4, and enable_pin !PC3).
I have tried the following troubleshooting steps:
  • Verified all physical connections and wiring.
  • Confirmed that the configuration parameters for the extruder are similar to the recommended settings.
  • Attempted manual extrusion with G1 E10 F300, but the extruder motor does not move.
  • Tried to run extruder motor on other axes it works on x,y,z … wire is also good
Could someone please advise on what else I might check or modify? I’m particularly curious if sharing the same enable_pin for all steppers could be causing issues or if there’s another configuration parameter I may have overlooked.
Thank you in advance for your help!
Best regards,
Vladimir
Your pin assignment for the extruder seems wrong. See klipper/config/printer-creality-ender3-v2-2020.cfg at 1fc6d214f4fab8b9e6a051fbe42f27ef4add77ef · Klipper3d/klipper · GitHub
I have tried that 1 also . step PB3 !PB3 PB4 !PB4 & for dir PB4 !PB4 PB3 !PB4.
Think i am losing my mind with this printer.
I think i did find out what is the problem, tried it out without bl touch & it works now. Back to thinkering, i will probably use z stop with some adapter for probing & later switching to LJ12A3-4-Z/BX Inductive Proximity Sensor. How much error do they make compared to bl touch ?
This seems unexpected and unusual.
Maybe your BLTouch is defective. It is known that a single defective hardware component can drag down the entire printer and lead to very strange effects.
Some people are big fans of inductive probes, while others (including myself) are not. I have good experiences with the BTT MicroProbe v2 and would recommend it over an inductive probe.
