Ender 3 pro 4.2.2 Sprite Extruder SE and Bltouch(clone)
Printer Model: Ender 3 Pro
MCU / Printerboard: 4.2.2
Describe your issue: Hello
I have an Ender 3 Pro 4.2.2 Bltouch device.
I installed Sprite Extruder SE.
Even though I searched on the internet and all the forums, I could not get the extruder to work. It does not push the filament. If there is anyone who can help or share the config file, I would be very happy.By the way sprite extruder may be a new model, I bought it from China.
Hello @baris !
Please attach it to your next post.
logs-20240206-210816.zip (99.9 KB)
I’m so sorry I added it now
How did you try this?
Did you use some gcode-commands? Or from the Web GUI?
yes I tried. I set the extruder to 200 degrees. I pressed the push filament button from the web interface. Extruder gear is shaking very slightly and does not turn
Your extruder stepper is most likely wired incorrectly for the driver. In my experience, reversing the middle two pins on one end of the cable (which ever is easier to do) will fix the problem.
I couldn’t find a good link to explain it but this isn’t a bad explanation of what to do if your steppers are vibrating and not turning:
Doesn’t it have anything to do with the config file?
No, in the config file you do not assign the output pins of the stepper driver.
