Hello, I’m having a problem with my printer. It was working fine for two years, but recently, it started disconnecting at the beginning of printing. The situation is standard: bytes_retransmit increases, and Transition to shutdown state: MCU shutdown occurs. However, it’s interesting that some models print normally, while others disconnect after 4-5 minutes. It’s possible that the issue is related to a recent update. I’ve tried turning off and on the MCU, but the connection only restores when I press FIRMWARE_RESTART. MCU F446 (V10) motherboard Printer, host orange pizero 3 Debian GNU/Linux 12 (bookworm), TronxyX5SA printer.
This shutdown happens because the MCU has been rebooted for some reason.
It seems to me that the clock is reset.
Maybe PSU has given up, and there is a drop of voltage, just a pure guess.
I checked the power supply and the MCU, and it seems to be working properly. The other model printed without any issues, but I think there might be a problem with the host. I will continue to investigate the cause.
