Calibrate after homing generates this error Move out of range: -22.000 -32.000 5.000 [0.000]
Printer Model: ender modified 400x400 bed
MCU / Printerboard: 42.27
Describe your issue: I am attempting to create a bed mesh, after i successfully home all, i press calibrate and keep getting this error.
i have re-set all offsets, bed meshes and can’t figure out what is
klippy.log (2.1 MB)
Hello @heavy !
Please check your mesh settings again!
The probe is 32 mm right to the nozzle.
The first test point is at 10. To move the probe to that position, the nozzle has to go way more left, to -22mm. That is the issue.
The same for the Y axes.
Thanks for the reply! This makes sense…to an extent. Ill look at the links you sent! My brain is short circuiting when trying to interpret bed mesh and xyz offsets which i have done repeatedly.
