Move out of range: X Y Z [E]
Background
A movement beyond the physical limits was attempted. Also refer to Understanding X and Y Axes Limits and Homing
Reasons
- A direct movement command (
G1et al.) tried to move to a location that is beyond the limits - An indirect movement correction (e.g. bed mesh or gcode offsets) pushed the movement target beyond the physical limits
Potential solutions
- How to determine the offending axis
- Check the X, Y or Z coordinates given in the error message and compare them with the limits of your axes (
position_min/position_maxin the[stepper]section) - Find the axis that is causing the error. For example the message
Move out of range: X Y -0.2 [0.000]compared toposition_min: 0makes it clear, where the error is coming from
- Check relevant movements that might be causing the exceeded limits
- Z-axis errors, especially when negative as in above example, are often caused by the bed-mesh. The mesh needs some head-room to be able to correct into the negative quadrant as well. Set
position_min: -2or similar to solve the issue G90(Absolut Positioning) vs.G92(Relative / Incremental Positioning): Care needs to be taken especially when usingG92positioning. Any movement will be added to the current position, making it easy to leave the specified boundaries- Probe coordinates:
mesh_min/mesh_maxrequire the probe coordinates and not the nozzle coordinates. Setting this wrongly, easily leads to this error - Screw coordinates: The screw coordinates for
SCREWS_TILT_CALCULATEin contrast require the nozzle coordinates at the location where the probe’s tip is ideally above the screw’s center.
