Setup
- Siboor Voron 2.4r2 kit from 2022-2023 converted to StealthChanger (4 toolheads)
- Motherbopard: BTT Octopus Pro v1.1
- Toolheads: 4× BTT EBB SB2209 (RP2040) v1.0
- USB-CAN adapters tried: BTT U2C v2.1 (factory firmware originally, now updated per Esoterical’s guide) and FYSETC UCAN v1.0 — both fail
- CAN hubs tried: Isik’s Tech MOAR_CAN and a DIY hub (parallel power distribution, CAN bus OUT from one head connected to IN of next) — both fail
- Host: Raspberry Pi 3B, MainsailOS 1.3.2 (Debian 11 Bullseye), kernel 6.1.21-v8+ aarch64. Note: this matches the combination Esoterical flags as causing timing issues. OS reflash is a significant operation (full Klipper/Moonraker/Mainsail rebuild) so I’d like some confirmation this could plausibly cause the specific symptoms described below — not just generic “timing issues” — before committing to it.
- Klipper 0.13.0-455, Katapult 0.0.1-91 on all toolheads
- Wiring: linear bus through the moar_can as designed. Power and CAN-out on SB2209’s XT30 (incoming + outgoing CANH/L crimped into same pin). Also tried using the SB2209 secondary board’s CANH/L breakout — identical failure either way.
- Cable: original SB2209 cable for outgoing leg, twisted pair from cat5e for return leg
- Bus length: ~7.7m total (1.3m from U2C to moar_can + 4× 1.6m round-trip to toolheads)
- Termination: 2× 120Ω, one at U2C, one at moar_can (PCB termination jumper populated). Measured 64Ω across bus, power off. Correct.
- 24V at each toolhead: stable at 24V+, no measurable sag
- Star ground at PSU. Each toolhead has dedicated 24V/GND back to moar_can common point
- Bitrate: tried 1Mbit and 500kbit on both adapters, identical failure at both
- txqueuelen 128, restart-ms 100 (systemd-networkd config)
Issue
CAN bus fails (BUS-OFF on U2C, persistent ERROR-PASSIVE on UCAN) with 3+ toolheads; works fine with any 2 out of 4. All physical-layer checks pass. Tried 2 USB to CAN bus adapters, 2 CAN bus hubs and both 1M and 500k bitrates.
Symptom
Any single toolhead works. Any pair works. Three or more active toolheads → bus fails within seconds of boot — U2C goes to BUS-OFF, UCAN holds in persistent ERROR-PASSIVE. Klipper logs repeated Timeout on connect / Serial connection closed for the first MCU it tries to enumerate either way.
The “which 2 work” is interchangeable — every combination of 2 I’ve tried works, no combination of 3 neither all 4 works.
Specific signature
With 2 toolheads (working): RX ~19 packets/sec, candump shows all of it, all error counters 0, state ERROR-ACTIVE.
With 3+ toolheads (failing): RX climbs at ~3,000+ packets/sec on U2C, ~25,000+/sec on UCAN, while candump captures almost nothing (only a few normal Klipper protocol frames from one node). Counters and candump don’t match — the controller is registering huge bus activity that doesn’t surface as valid frames. The bus-errors counter stays at 0 throughout, despite massive RX accumulation and bus-off/error-passive events. TX failures with no valid ACKs.
U2C: goes through ERROR-WARN → ERROR-PASSIVE → BUS-OFF rapidly.
UCAN: holds in ERROR-PASSIVE persistently, error-pass counter climbs into the millions without progressing to bus-off.
Example U2C output after a failure:
can state BUS-OFF restart-ms 100
bitrate 500000 sample-point 0.875
re-started bus-errors arbit-lost error-warn error-pass bus-off
0 0 0 3 3 2
RX: bytes 17717569 packets 2214713 errors 0 dropped 67
TX: bytes 24 packets 3 errors 0 dropped 10
Example UCAN output after a similar failure window:
can state ERROR-PASSIVE restart-ms 100
0 0 0 32 1161925 0
RX: bytes 9296416 packets 1162052 errors 0 dropped 67
TX: bytes 18 packets 4 errors 0 dropped 0
Relevant note on can2040 behavior
The SB2209 RP2040 uses can2040 (Kevin O’Connor’s software CAN implementation), which per its own documentation does not implement automatic bus-off transitions and does not transmit error frames. Static analysis of can2040.c confirms: no SJW/TSEG/PHASE_SEG configurable parameters, no bus-off state machine, no escalation past discarding malformed messages. Bit timing is hard-coded at 32 PIO clocks per CAN bit; resync is implemented in PIO assembly.
This may explain the host-side asymmetry (host goes bus-off or persistent error-passive while toolheads keep retrying indefinitely), but does not explain why the threshold is 3 nodes or why the bus floods with invisible-to-candump traffic.
Outstanding hypotheses I haven’t been able to confirm or rule out
The OS combination (Bullseye + kernel 6.1 + aarch64) Esoterical warns about — would appreciate input on whether this could plausibly cause the specific signature above before I commit to the OS reflash. I know some will think this is the obvious next step but as I said changing the OS is a mayor PITA and would like some evidence supporting it as a cause for this issue. I had been using the same OS before converting to Stealthchanger/CAN bus with zero problems.
Some interaction between can2040’s non-standard error handling and the host adapter’s standard CAN state machine that only manifests with 3+ active nodes
What I’m asking
Has anyone seen this specific signature — bus failure (BUS-OFF or persistent ERROR-PASSIVE) via TX errors with bus-errors counter staying at 0, massive RX counter accumulation that doesn’t appear in candump, threshold at exactly 3 nodes, bitrate-independent, identical across two adapters and two hubs?
Particularly interested in input from anyone with multi-toolhead/IDEX/toolchanger experience, anyone who’s debugged gs_usb driver issues at this depth, or anyone with can2040 internals knowledge.
Ruled out (with measurements where applicable)
Termination (60-65Ω measured, no extra terminators anywhere)
Topology / stubs (true linear bus through moar_can, ~12mm physical stubs)
Cabling (CANH/L on twisted pairs throughout)
Bus length (7.7m, well within spec at both 500k and 1M)
Power delivery (24V solid at each head)
Ground (star at PSU, dedicated returns)
Bitrate (fails at both 1M and 500k)
txqueuelen (tried 128, 256, and 1000/1024 at various points — current value 128 per Klipper docs recommendation; no observable change in failure behavior at any value)
SJW on host side (tested SJW=2 — accepted by gs_usb driver but no change in failure behavior)
Individual toolhead health (each works solo, all pair combinations work)
USB-CAN adapter (both U2C and UCAN fail; different behaviors, same outcome)
USB-CAN adapter firmware (U2C factory firmware updated per Esoterical, no change)
Bridge mode (using transparent gs_usb / candleLight firmware, not Klipper bridge)
Hubs (MOAR_CAN and DIY hub both fail)
moar_can per-port jumpers (correctly populated for unused ports when relevant)
The “two wires in one crimp” connection at SB2209 (changed approach mid-project, no behavior change)
Solo MCU health (each toolhead enumerates fine when alone on the bus)
klippy2.log (444.1 KB)
