Hello friends. Can there be a second virtual structure without touching the system and configuration files of our current printer? A second klipper system and config file. The purpose of this structure is to experience, test and make necessary changes to new macros and settings without affecting the problem-free system and without changing its settings. and to protect the solid system structure. To put it simply; it is like installing two windows in a hdd. When we turned on the computer, it would ask us which system it would boot into. Or we would have it boot through a fixed operating system.
Use KIAUH to install a second instance of Klipper and just use the same configuration files that you use for your first instance.
Make sure not to start both at the same time; for example, deactivate the autostart of the second Klipper instance.
hi sineos… I saw it when I looked at KIUAH based on your guidance. thank you very much.
then:
When we install a second configuration via KIUAh, will we use the “mcu serial id” information we used in the first system. or will we create a new “mcu serial id” for the 2nd clipper system with a new “make config” command.
You only need to install a second instance of Klipper on the host system.
- You do not need to run through
make menuconfig
or build new firmware. - You will not need to use any new serial ID.
- You just supply the new instance with its own
printer.cfg
, which is identical to the already running one. - Klipper’s entire configuration is done in the
printer.cfg
and is independent of the firmware on the boards (at least in terms of configuration).
thank you. this information answered all the questions in my mind.
