Klipper Multi instance after mono instance installation
Hi Everyone !
I would like to know if there is any solution to add a klipper instance for a second printer when having already install and an klipper instance running.
i Would like to add the second instance without touching the original configuration.
Thanks :slight_smile: !
Happy new year !
See can-i-run-multiple-instances-of-klipper-on-the-same-host-machine
Thanks i will try the command.
