Can you not use a custom thermistor for a temperature_fan?
I get Unknown temperature sensor 'CMFB103F3950FANT' for the following config.
[temperature_fan exhaust_fan]
pin: PD14
sensor_type: CMFB103F3950FANT
sensor_pin: PF5
min_temp: 0
max_temp: 100
control: watermark
[thermistor CMFB103F3950FANT]
temperature1: 0.0
resistance1: 32116.0
temperature2: 40.0
resistance2: 5309.0
temperature3: 80.0
resistance3: 1228.0
But I can use it just as a temp sensor without error.
[temperature_sensor chamber]
## Chamber Temperature - T1
sensor_pin: PF5
min_temp: 0
max_temp: 100
gcode_id: chamber_th
I obviously comment out that when I try to use temperature_fan so I am not using the pin twice.
https://www.klipper3d.org/Config_Reference.html#thermistor
The order of definitions in the config is important. You need to define the thermistor before you use it elsewhere in the config. Simply moving the thermistor above the temperature_fan should fix it.
That did the trick. Documentation should probably remind users of this in the custom thermistor section.
It’s already there:
“Be sure to place the thermistor section in the config file above its first use in a heater section.”
Ah, I see my thought process. It says “heater section” and I am using it in the fan section and I didn’t put two and two together. Then I guess it should be changed to something like…
“Be sure to place the thermistor section in the config file above its first reference as a sensor type or it won’t be recognized as a known sensor.”
… for idiots like myself. :upside_down_face:
