How to read the temperature of a temperature_fan?
I have a temperature_fan setup like this:
[temperature_fan exhaust_fan]
pin: PD13
shutdown_speed: 0.0
kick_start_time: 0.5
sensor_type: Generic 3950
sensor_pin: PF6
gcode_id: C
control: pid
min_temp: 0
max_temp: 100
max_speed: 0.85
min_speed: 0.0
pid_Kp:  20
pid_Ki: 20
pid_Kd: 20
pid_deriv_time: 2.0
gcode_id: CHAMBER
Which works as far as it goes.
Now I’d like to use the same temperature sensor to wait until my chamber gets to 80% of whatever I pass from PRINT_START. I’d also like to use it for z_thermal_adjust
But this: TEMPERATURE_WAIT SENSOR=exhaust_fan MINIMUM={params.S}
Fails because it doesn’t understand exhaust_fan to get the sensor.
And of course I can’t pass that into the z_thermal_adjust either.
How do I get the exhaust_fan’s temperature sensor for these commands?
Idea with question:
We can define a standalone [Temperature Sensor]. Couldn’t it then be queried from several places?
Try
TEMPERATURE_WAIT SENSOR=“temperature_fan exhaust_fan” MINIMUM={params.S}
Try
That’s the trick, thanks!
