Printer Model: N/A
MCU / Printerboard: MKS SKIPR v1.0
Host / SBC: MKS SKIPR v1.0
I am giving up with stock boards on my Twotrees SK1, which are too unstable, and purchased a MKS SKIPR board instead. In the meantime I installed pretty fresh Armbian, using KIAUH installed moonraker, klipper, fluidd, and other stuff.
Unfortunately I hit an issue uploading klipper firmware to MCU. I pretty much followed build recommendations, and compiled klipper for STM32F407 MCU, 48k bootloader, UART1 on PA10/PA9 communication. To flash the firmware I used this command line:
make serialflash FLASH_DEVICE=/dev/ttyS0
With pressing BOOT button while reset, this command uploads the firmware without any errors.
As per instructions, printer config includes this section
serial: /dev/ttyS0
restart_method: command
Unfortunately klipper can’t connect to the MCU.
mks@mkspi:~$ ~/klippy-env/bin/python ~/klipper/klippy/console.py /dev/ttyS0
This is a debugging console for the Klipper micro-controller.
In addition to mcu commands, the following artificial commands are
available:
DELAY : Send a command at a clock time (eg, "DELAY 9999 get_uptime")
FLOOD : Send a command many times (eg, "FLOOD 22 .01 get_uptime")
SUPPRESS : Suppress a response message (eg, "SUPPRESS analog_in_state 4")
SET : Create a local variable (eg, "SET myvar 123.4")
DUMP : Dump memory (eg, "DUMP 0x12345678 100 32")
FILEDUMP : Dump to file (eg, "FILEDUMP data.bin 0x12345678 100 32")
STATS : Report serial statistics
LIST : List available mcu commands, local commands, and local variables
HELP : Show this text
All commands also support evaluation by enclosing an expression in { }.
For example, "reset_step_clock oid=4 clock={clock + freq}". In addition
to user defined variables (via the SET command) the following builtin
variables may be used in expressions:
clock : The current mcu clock time (as estimated by the host)
freq : The mcu clock frequency
==================== attempting to connect ====================
INFO:root:Starting serial connect
INFO:root:Timeout on connect
ERROR:root:Wait for identify_response
File "/home/mks/klipper/klippy/serialhdl.py", line 68, in _get_identify_data
params = self.send_with_response(msg, 'identify_response')
File "/home/mks/klipper/klippy/serialhdl.py", line 262, in send_with_response
File "/home/mks/klipper/klippy/serialhdl.py", line 319, in get_response
self.serial.raw_send_wait_ack(cmds[-1], minclock, reqclock,
File "/home/mks/klipper/klippy/serialhdl.py", line 254, in raw_send_wait_ack
self._error("Serial connection closed")
File "/home/mks/klipper/klippy/serialhdl.py", line 61, in _error
serialhdl.error: Serial connection closed
I also tried the flashing way suggested by the manufacturer:
- built the klipper
- renamed klipper.bin to mks_skipr.bin, and uploaded to a FAT32 SD card
- insterted the card to the MCU SD Card slot
- powered on the board, and waited for a few minutes
Unfortunately the firmware did not flash, no files on the SD card updated, or renamed to *.CUR, indicating the firmware flashed successully.
What could be wrong, and how I can upload the firmware to MCU?
I suspect that by using serialflash utility I overwrote the SD-card bootloader. So perhaps I need to flash bootloader first, and only then flash the firmware.
