Printer Model: Custom klippy.log klippy.log (86.6 KB) winch.py winch.txt (4.7 KB) kin_winch.py kin_winch.txt (1.4 KB) Greetings. I am building a custom 3D-printer. Currently I am using “winch” kinematics, although it’s somewhat different comparing to other kinematics. My printer uses 4 carriages. To move base along the x axis all of them should move in sync..
I am trying to set up parking using “winch” kinematics. Parking along x axis finishes just fine, but along other axes (y and z) the program stops and returns an error “cannot convert float NaN to integer”. I found out, that in file stepper.py variable mcu_pos = nan. I don’t understand why is it this way. If you have any ideas why and how to fix this error please tell me. The files of kinematics and programs are attached.
The Klipper has cable winch kinematics, I just changed the file a bit for my printer. My printer kinematics moves on four carriages. If you need to move on the x-axis all carriages should move simultaneously to the left or right, on the y-axis the first and second carriages move towards each other, the third and fourth carriages move apart or vice versa, on the z-axis all carriages move towards each other. if you need a video i can send you, but for now i think a picture and explanation of the movement should be enough.
I have the delta kinematics code for my printer, but it has the same error. delta.txt (13.9 KB)
Interesting. Alas, I can’t provide any meaningful help on errors produced with modified code. If you can produce the error with unmodified code then I can take a look at it, otherwise the likely explanation is that something in the new code is the cause of the problem.
