Hi there,
i make my first Steps with KLipper and iv got two Problems i cant solve allone.
2 different PCs are used for Test:
Raspberry Pi 3B
ASUS Eee Top PC with Raspbian / Mainsail / Moonraker / KlipperScreen
Im using an Artillery Genius Printer.
On both PCs i be able to make the bed_mesh_leveling Procedure.
After that, i tap on “Accept” and than on “Continue”.
If i tap on “Continue” , the complete System freezed and i must do a hard reset.
If i use the Web UI and click on “Save Config”, this works! Only on KlipperScreen it does not.
The second Problem is a overheating Bed Temperature,
I read this:
opened 07:01PM - 26 Jun 21 UTC
closed 12:07AM - 27 Mar 22 UTC
Stale
Me and some other users on the Artillery Discord have been trying to solve the p… roblem of the bed temperature overshooting and basically "soft locking" the print because it never goes back down.
(manually stopped here)
When I use the PID values I still have of my marlin installation it also overshoots but swiftly recovers.
The values produced by each PID tune are also VERY different as seen here.
but it dont worked for me.
If i try to put “smoothing time=4” the Bed Temperature is 4,5 to high, before it was 2 degree.
What i can do now?
All Software Packages are up to date.
Thanks!
Sineos
January 29, 2023, 9:23am
2
As first step post your klippy.log file
klippy.log (17.5 KB)
The Printer is not attached today.
Sineos
January 29, 2023, 11:29am
4
Well, ideally the log should contain the problem / error you are fighting with and not only show an offline printer.
klippy.log (339.2 KB)
Of course, thats it.
And it is the Z_Offset Procedure not bed-mesh-leveling, sorry.
On WEB GUI i get the Message “Klipper is reporting shutdown”
Today i flashed the Printer Mainboard again and it seams that the Bed-Temperature Problem is gone.
Sineos
January 29, 2023, 3:07pm
6
I’m not quite sure, what you are reporting. The last log shows a pretty regular Z-Offset tuning
Z position: ?????? --> 5.080 <-- 6.080
Heater heater_bed within range of 60.000
Stats 179.9: gcodein=0 mcu: mcu_awake=0.010 mcu_task_avg=0.000094 mcu_task_stddev=0.000076 bytes_write=20287 bytes_read=28161 bytes_retransmit=9 bytes_invalid=6 send_seq=1189 receive_seq=1189 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=16000662 heater_bed: target=60 temp=55.8 pwm=0.439 sysload=0.64 cputime=6.485 memavail=695340 print_time=145.714 buffer_time=0.072 print_stall=0 extruder: target=0 temp=68.3 pwm=0.000
Stats 180.9: gcodein=0 mcu: mcu_awake=0.012 mcu_task_avg=0.000105 mcu_task_stddev=0.000106 bytes_write=20333 bytes_read=28286 bytes_retransmit=9 bytes_invalid=6 send_seq=1192 receive_seq=1192 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=16000662 heater_bed: target=60 temp=56.2 pwm=0.122 sysload=0.64 cputime=6.503 memavail=695340 print_time=145.714 buffer_time=0.000 print_stall=0 extruder: target=0 temp=68.0 pwm=0.000
Z position: ?????? --> 4.080 <-- 5.080
Stats 181.9: gcodein=0 mcu: mcu_awake=0.012 mcu_task_avg=0.000105 mcu_task_stddev=0.000106 bytes_write=20648 bytes_read=28435 bytes_retransmit=9 bytes_invalid=6 send_seq=1200 receive_seq=1200 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=10 stalled_bytes=0 freq=16000662 heater_bed: target=60 temp=56.1 pwm=0.497 sysload=0.64 cputime=6.531 memavail=695308 print_time=147.825 buffer_time=0.181 print_stall=0 extruder: target=0 temp=68.0 pwm=0.000
Stats 182.9: gcodein=0 mcu: mcu_awake=0.012 mcu_task_avg=0.000105 mcu_task_stddev=0.000106 bytes_write=20699 bytes_read=28564 bytes_retransmit=9 bytes_invalid=6 send_seq=1204 receive_seq=1204 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=16000661 heater_bed: target=60 temp=56.5 pwm=0.199 sysload=0.64 cputime=6.550 memavail=695444 print_time=147.825 buffer_time=0.000 print_stall=0 extruder: target=0 temp=67.9 pwm=0.000
Z position: ?????? --> 3.080 <-- 4.080
Stats 183.9: gcodein=0 mcu: mcu_awake=0.012 mcu_task_avg=0.000105 mcu_task_stddev=0.000106 bytes_write=20991 bytes_read=28694 bytes_retransmit=9 bytes_invalid=6 send_seq=1211 receive_seq=1211 retransmit_seq=2 srtt=0.004 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=16000661 heater_bed: target=60 temp=56.6 pwm=0.330 sysload=0.64 cputime=6.573 memavail=695476 print_time=149.760 buffer_time=0.114 print_stall=0 extruder: target=0 temp=68.0 pwm=0.000
Stats 184.9: gcodein=0 mcu: mcu_awake=0.012 mcu_task_avg=0.000105 mcu_task_stddev=0.000106 bytes_write=21025 bytes_read=28818 bytes_retransmit=9 bytes_invalid=6 send_seq=1214 receive_seq=1214 retransmit_seq=2 srtt=0.004 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=16000661 heater_bed: target=60 temp=57.1 pwm=0.000 sysload=0.59 cputime=6.594 memavail=695500 print_time=149.760 buffer_time=0.000 print_stall=0 extruder: target=0 temp=68.1 pwm=0.000
Z position: ?????? --> 2.080 <-- 3.080
Stats 185.9: gcodein=0 mcu: mcu_awake=0.015 mcu_task_avg=0.000126 mcu_task_stddev=0.000140 bytes_write=21340 bytes_read=28982 bytes_retransmit=9 bytes_invalid=6 send_seq=1222 receive_seq=1222 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=16000660 heater_bed: target=60 temp=56.7 pwm=0.659 sysload=0.59 cputime=6.619 memavail=695508 print_time=151.461 buffer_time=0.000 print_stall=0 extruder: target=0 temp=67.5 pwm=0.000
Stats 186.9: gcodein=0 mcu: mcu_awake=0.015 mcu_task_avg=0.000126 mcu_task_stddev=0.000140 bytes_write=21391 bytes_read=29097 bytes_retransmit=9 bytes_invalid=6 send_seq=1226 receive_seq=1226 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=16000660 heater_bed: target=60 temp=57.3 pwm=0.025 sysload=0.59 cputime=6.638 memavail=695500 print_time=151.461 buffer_time=0.000 print_stall=0 extruder: target=0 temp=67.3 pwm=0.000
Z position: ?????? --> 1.080 <-- 2.080
Stats 187.9: gcodein=0 mcu: mcu_awake=0.015 mcu_task_avg=0.000126 mcu_task_stddev=0.000140 bytes_write=21688 bytes_read=29236 bytes_retransmit=9 bytes_invalid=6 send_seq=1232 receive_seq=1232 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=8 stalled_bytes=0 freq=16000660 heater_bed: target=60 temp=57.6 pwm=0.000 sysload=0.59 cputime=6.665 memavail=694780 print_time=153.587 buffer_time=0.000 print_stall=0 extruder: target=0 temp=67.5 pwm=0.000
Stats 188.9: gcodein=0 mcu: mcu_awake=0.015 mcu_task_avg=0.000126 mcu_task_stddev=0.000140 bytes_write=21753 bytes_read=29370 bytes_retransmit=9 bytes_invalid=6 send_seq=1237 receive_seq=1237 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=16000659 heater_bed: target=60 temp=57.0 pwm=1.000 sysload=0.59 cputime=6.682 memavail=694732 print_time=153.587 buffer_time=0.000 print_stall=0 extruder: target=0 temp=67.3 pwm=0.000
Z position: ?????? --> 0.080 <-- 1.080
Stats 189.9: gcodein=0 mcu: mcu_awake=0.015 mcu_task_avg=0.000126 mcu_task_stddev=0.000140 bytes_write=22068 bytes_read=29505 bytes_retransmit=9 bytes_invalid=6 send_seq=1245 receive_seq=1245 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=16000659 heater_bed: target=60 temp=57.9 pwm=0.000 sysload=0.54 cputime=6.703 memavail=694776 print_time=155.406 buffer_time=0.000 print_stall=0 extruder: target=0 temp=67.0 pwm=0.000
Stats 190.9: gcodein=0 mcu: mcu_awake=0.014 mcu_task_avg=0.000118 mcu_task_stddev=0.000127 bytes_write=22119 bytes_read=29649 bytes_retransmit=9 bytes_invalid=6 send_seq=1249 receive_seq=1249 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=10 stalled_bytes=0 freq=16000658 heater_bed: target=60 temp=57.4 pwm=0.634 sysload=0.54 cputime=6.721 memavail=694760 print_time=155.406 buffer_time=0.000 print_stall=0 extruder: target=0 temp=67.0 pwm=0.000
Stats 191.9: gcodein=0 mcu: mcu_awake=0.014 mcu_task_avg=0.000118 mcu_task_stddev=0.000127 bytes_write=22186 bytes_read=29794 bytes_retransmit=9 bytes_invalid=6 send_seq=1254 receive_seq=1254 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=16000658 heater_bed: target=60 temp=57.8 pwm=0.153 sysload=0.54 cputime=6.742 memavail=694776 print_time=155.406 buffer_time=0.000 print_stall=0 extruder: target=0 temp=66.6 pwm=0.000
Stats 192.9: gcodein=0 mcu: mcu_awake=0.014 mcu_task_avg=0.000118 mcu_task_stddev=0.000127 bytes_write=22237 bytes_read=29909 bytes_retransmit=9 bytes_invalid=6 send_seq=1258 receive_seq=1258 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=16000658 heater_bed: target=60 temp=57.8 pwm=0.489 sysload=0.54 cputime=6.763 memavail=694776 print_time=155.406 buffer_time=0.000 print_stall=0 extruder: target=0 temp=66.7 pwm=0.000
Z position: 0.080 --> 0.580 <-- 1.080
Stats 193.9: gcodein=0 mcu: mcu_awake=0.014 mcu_task_avg=0.000118 mcu_task_stddev=0.000127 bytes_write=22831 bytes_read=30083 bytes_retransmit=9 bytes_invalid=6 send_seq=1271 receive_seq=1271 retransmit_seq=2 srtt=0.004 rttvar=0.001 rto=0.025 ready_bytes=10 stalled_bytes=0 freq=16000657 heater_bed: target=60 temp=58.2 pwm=0.184 sysload=0.54 cputime=6.792 memavail=693608 print_time=159.819 buffer_time=0.167 print_stall=0 extruder: target=0 temp=66.7 pwm=0.000
Stats 194.9: gcodein=0 mcu: mcu_awake=0.014 mcu_task_avg=0.000118 mcu_task_stddev=0.000127 bytes_write=22895 bytes_read=30217 bytes_retransmit=9 bytes_invalid=6 send_seq=1276 receive_seq=1276 retransmit_seq=2 srtt=0.003 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=16000657 heater_bed: target=60 temp=58.2 pwm=0.379 sysload=0.58 cputime=6.810 memavail=693560 print_time=159.819 buffer_time=0.000 print_stall=0 extruder: target=0 temp=66.8 pwm=0.000
Z position: 0.080 --> 0.480 <-- 0.580
Stats 195.9: gcodein=0 mcu: mcu_awake=0.015 mcu_task_avg=0.000120 mcu_task_stddev=0.000130 bytes_write=23417 bytes_read=30382 bytes_retransmit=9 bytes_invalid=6 send_seq=1287 receive_seq=1287 retransmit_seq=2 srtt=0.004 rttvar=0.001 rto=0.025 ready_bytes=54 stalled_bytes=0 freq=16000657 heater_bed: target=60 temp=58.2 pwm=0.403 sysload=0.58 cputime=6.839 memavail=693860 print_time=162.156 buffer_time=0.502 print_stall=0 extruder: target=0 temp=66.4 pwm=0.000
Stats 196.9: gcodein=0 mcu: mcu_awake=0.015 mcu_task_avg=0.000120 mcu_task_stddev=0.000130 bytes_write=23527 bytes_read=30516 bytes_retransmit=9 bytes_invalid=6 send_seq=1292 receive_seq=1292 retransmit_seq=2 srtt=0.003 rttvar=0.001 rto=0.025 ready_bytes=10 stalled_bytes=0 freq=16000657 heater_bed: target=60 temp=58.6 pwm=0.115 sysload=0.58 cputime=6.857 memavail=693860 print_time=162.156 buffer_time=0.000 print_stall=0 extruder: target=0 temp=66.6 pwm=0.000
Stats 197.9: gcodein=0 mcu: mcu_awake=0.015 mcu_task_avg=0.000120 mcu_task_stddev=0.000130 bytes_write=23588 bytes_read=30645 bytes_retransmit=9 bytes_invalid=6 send_seq=1296 receive_seq=1296 retransmit_seq=2 srtt=0.004 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=16000657 heater_bed: target=60 temp=58.6 pwm=0.219 sysload=0.58 cputime=6.874 memavail=694048 print_time=162.156 buffer_time=0.000 print_stall=0 extruder: target=0 temp=66.1 pwm=0.000
Z position: 0.080 --> 0.380 <-- 0.480
Stats 198.9: gcodein=0 mcu: mcu_awake=0.015 mcu_task_avg=0.000120 mcu_task_stddev=0.000130 bytes_write=24182 bytes_read=30805 bytes_retransmit=9 bytes_invalid=6 send_seq=1309 receive_seq=1309 retransmit_seq=2 srtt=0.004 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=16000657 heater_bed: target=60 temp=58.6 pwm=0.464 sysload=0.58 cputime=6.904 memavail=694116 print_time=164.549 buffer_time=0.000 print_stall=0 extruder: target=0 temp=66.2 pwm=0.000
Stats 199.9: gcodein=0 mcu: mcu_awake=0.015 mcu_task_avg=0.000120 mcu_task_stddev=0.000130 bytes_write=24203 bytes_read=30924 bytes_retransmit=9 bytes_invalid=6 send_seq=1311 receive_seq=1311 retransmit_seq=2 srtt=0.004 rttvar=0.000 rto=0.025 ready_bytes=10 stalled_bytes=0 freq=16000656 heater_bed: target=60 temp=58.8 pwm=0.286 sysload=0.53 cputime=6.923 memavail=694116 print_time=164.549 buffer_time=0.000 print_stall=0 extruder: target=0 temp=66.0 pwm=0.000
Z position: 0.080 --> 0.280 <-- 0.380
Stats 200.9: gcodein=0 mcu: mcu_awake=0.015 mcu_task_avg=0.000120 mcu_task_stddev=0.000130 bytes_write=24814 bytes_read=31103 bytes_retransmit=9 bytes_invalid=6 send_seq=1325 receive_seq=1325 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=16000656 heater_bed: target=60 temp=59.0 pwm=0.085 sysload=0.53 cputime=6.950 memavail=694124 print_time=166.325 buffer_time=0.000 print_stall=0 extruder: target=0 temp=66.1 pwm=0.000
Z position: 0.080 --> 0.180 <-- 0.280
Stats 201.9: gcodein=0 mcu: mcu_awake=0.022 mcu_task_avg=0.000149 mcu_task_stddev=0.000165 bytes_write=25398 bytes_read=31268 bytes_retransmit=9 bytes_invalid=6 send_seq=1336 receive_seq=1336 retransmit_seq=2 srtt=0.004 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=16000658 heater_bed: target=60 temp=59.0 pwm=0.315 sysload=0.53 cputime=6.977 memavail=694124 print_time=167.955 buffer_time=0.295 print_stall=0 extruder: target=0 temp=65.7 pwm=0.000
Stats 202.9: gcodein=0 mcu: mcu_awake=0.022 mcu_task_avg=0.000149 mcu_task_stddev=0.000165 bytes_write=25449 bytes_read=31397 bytes_retransmit=9 bytes_invalid=6 send_seq=1340 receive_seq=1340 retransmit_seq=2 srtt=0.004 rttvar=0.000 rto=0.025 ready_bytes=8 stalled_bytes=0 freq=16000658 heater_bed: target=60 temp=59.5 pwm=0.000 sysload=0.53 cputime=6.999 memavail=694124 print_time=167.955 buffer_time=0.000 print_stall=0 extruder: target=0 temp=65.7 pwm=0.000
Stats 203.9: gcodein=0 mcu: mcu_awake=0.022 mcu_task_avg=0.000149 mcu_task_stddev=0.000165 bytes_write=25498 bytes_read=31526 bytes_retransmit=9 bytes_invalid=6 send_seq=1344 receive_seq=1344 retransmit_seq=2 srtt=0.004 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=16000658 heater_bed: target=60 temp=59.0 pwm=0.663 sysload=0.53 cputime=7.018 memavail=694124 print_time=167.955 buffer_time=0.000 print_stall=0 extruder: target=0 temp=65.6 pwm=0.000
bltouch: z_offset: 0.900
The SAVE_CONFIG command will update the printer config file
with the above and restart the printer.
save_config: set [bltouch] z_offset = 0.900
Stats 204.9: gcodein=0 mcu: mcu_awake=0.022 mcu_task_avg=0.000149 mcu_task_stddev=0.000165 bytes_write=25542 bytes_read=31636 bytes_retransmit=9 bytes_invalid=6 send_seq=1347 receive_seq=1347 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=16000658 heater_bed: target=60 temp=59.6 pwm=0.000 sysload=0.49 cputime=7.041 memavail=692364 print_time=167.955 buffer_time=0.000 print_stall=0 extruder: target=0 temp=65.4 pwm=0.000
Stats 205.9: gcodein=0 mcu: mcu_awake=0.022 mcu_task_avg=0.000149 mcu_task_stddev=0.000165 bytes_write=25591 bytes_read=31765 bytes_retransmit=9 bytes_invalid=6 send_seq=1351 receive_seq=1351 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=16000658 heater_bed: target=60 temp=59.3 pwm=0.398 sysload=0.49 cputime=7.060 memavail=692348 print_time=167.955 buffer_time=0.000 print_stall=0 extruder: target=0 temp=65.4 pwm=0.000
Stats 206.9: gcodein=0 mcu: mcu_awake=0.014 mcu_task_avg=0.000117 mcu_task_stddev=0.000130 bytes_write=25640 bytes_read=31909 bytes_retransmit=9 bytes_invalid=6 send_seq=1355 receive_seq=1355 retransmit_seq=2 srtt=0.003 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=16000658 heater_bed: target=60 temp=59.8 pwm=0.000 sysload=0.49 cputime=7.083 memavail=692112 print_time=167.955 buffer_time=0.000 print_stall=0 extruder: target=0 temp=65.2 pwm=0.000
There is no indication of an error.
Ok, the Klipperscreen is freezed after tap on “Continue” and i must disconnect the PC from Power supply.
I will click on “Save Config” in WEBGUI. This works.
Can it be that the crash is so fast that the log cannot be created?
Sineos
January 29, 2023, 4:20pm
8
No.
Does it only happen in KlipperScreen?
Does it also happen in fluidd / mainsail?
Please attach your moonraker.log
Now its gone crazy:
I compiled and flashed the Firmware for the Printer Mainboard with the PC (Eee Top ASUS)
and connected the Printer with my Raspberry Pi 3B. (First Combination with Problems to).
And now all Things working fine!?
The first Firmware was compiled with the Raspberry PI. (bullseye on both Devices)
I knew, that Compilers are different between OS Versions, but this??
I dont know why, but Problem is solved.
I would have liked to know what that was about
Its only happnd in KlipperScreen… The WEB GUI works fine.
