Hi mates and thank again for you time…
I did a test by switching back to Marlin with fork tiny machine and on octoprint the bed seems to be much better, much better.
Here is a picture:
Then I re-installed klipper from scratch, and redid all procedures and settings. But nothing seems to have changed.
I show you the results of the measurements but it seems not to change nothing although everything seems perfect.
SCREWS_TILT_CALCULATE
// LF (Base): X 55.0, Y 34.9, Z 1.76983
// RF : X 300.0, Y 34.9, Z 1.78067 : Adjust -> CCW 00:01
// RB: X 300.0, Y 278.0, Z 1.77400 : Adjust -> CCW 00:01
// LB : X 54.0, Y 278.0, Z 1.77150 : Adjust -> CCW 00:00
apparently it looks almost perfect
PROBE_ACCURACY
$ probe_accuracy
// PROBE_ACCURACY at X:177.000 Y:155.000 Z:10.000 (samples=10 retract=3.000 speed=4.0 lift_speed=4.0)
// probe at 177.000,155.000 is z=1.714000
// probe at 177.000,155.000 is z=1.716500
// probe accuracy results: maximum 1.716500, minimum 1.714000, range 0.002500, average 1.714750, median 1.714000, standard deviation 0.001146
I’m not sure but it would seem ok
I tried again the level of the bed at room temperature, still wrong and I don’t understand how this is possible
#*# [bltouch]
#*# z_offset = 1.719
#*# [bed_mesh default]
#*# version = 1
#*# points =
#*# 0.070000, -0.008333, -0.062500, -0.055000, -0.030833, 0.063333
#*# 0.087500, 0.040000, -0.021667, -0.030000, 0.010833, 0.048333
#*# 0.037500, 0.030000, 0.010833, 0.016667, 0.021667, 0.043333
#*# 0.015000, -0.020000, -0.040833, -0.017500, -0.015000, 0.010000
#*# -0.013333, -0.039167, -0.065833, -0.070833, -0.033333, 0.010833
#*# -0.127500, -0.175833, -0.217500, -0.194167, -0.150000, -0.093333
#*# tension = 0.2
#*# min_x = 5.0
#*# algo = bicubic
#*# y_count = 6
#*# mesh_y_pps = 2
#*# min_y = 5.0
#*# x_count = 6
#*# max_y = 305.0
#*# mesh_x_pps = 2
#*# max_x = 268.0
Bad Mesh Screenshot - printer.cfg - Google Drive
I don’t really know what I can do at this point.
Maybe I should try setting the z_tilt and z_tilt_adjust, but I have no idea how to do this and haven’t found a comprehensive beginner’s guide.
I’ll try to reduce the probe air and see what happens
Attach my new printer.cfg and klippy.log
