Can't install moonraker
Printer Model: Modifyed Tevo Tornado
MCU / Printerboard: Atmega 2560 / MKS GEN L v1.0
Host / SBC Orange Pi One with 512 Mb RAM
After some unsuccessful changes, ARMBIAN crashed. I decided to install a new image using the Armbian imager. Armbian version 26.8.3, trixie, tty 1. I created the klipper account, gave it sudo privileges, dilout ttl , and made some changes to visudo. After that, I installed git, the zlib1g-dev and libjpeg-dev libraries, and then proceeded to install kiauh . Klipper then installed without errors. However, Moonraker would occasionally freeze or return an error like
error: subprocess-exited-with-error
× pip subprocess to install build dependencies did not run successfully.
│ exit code: 1
╰─> \[20 lines of output\]
Looking in links: /home/klipper/moonraker/scripts/python_wheels
Collecting setuptools>=65.4.1
Using cached setuptools-84.0.0-py3-none-any.whl.metadata (6.6 kB)
Collecting wheel
Using cached wheel-0.48.0-py3-none-any.whl.metadata (2.3 kB)
Collecting Cython<3.3.0,>=3
Using cached cython-3.2.9-cp39-abi3-manylinux2014_armv7l.manylinux_2_17_armv7l.manylinux_2_31_armv7l.whl.metadata (4.6 kB)
Collecting poetry-core>=1.0.0
Using cached poetry_core-2.4.1-py3-none-any.whl.metadata (3.8 kB)
Collecting packaging>=24.0 (from wheel)
Using cached packaging-26.3-py3-none-any.whl.metadata (3.5 kB)
Using cached cython-3.2.9-cp39-abi3-manylinux2014_armv7l.manylinux_2_17_armv7l.manylinux_2_31_armv7l.whl (2.9 MB)
Using cached setuptools-84.0.0-py3-none-any.whl (818 kB)
Using cached wheel-0.48.0-py3-none-any.whl (33 kB)
Using cached poetry_core-2.4.1-py3-none-any.whl (374 kB)
Using cached packaging-26.3-py3-none-any.whl (129 kB)
Installing collected packages: setuptools, poetry-core, packaging, Cython, wheel
ERROR: Could not install packages due to an OSError: \[Errno 28\] No space left on device
end of output
note: This error originates from a subprocess, and is likely not a problem with pip.
│ exit code: 1
╰─> See above for output.
[ERROR] Error installing Python requirements: Installing Python requirements failed!
[ERROR] Error during installation of Moonraker requirements!
[ERROR] Traceback (most recent call last):
File “/home/klipper/kiauh/kiauh/utils/sys_utils.py”, line 260, in install_python_requirements
raise VenvCreationFailedException(“Installing Python requirements failed!”)
utils.sys_utils.VenvCreationFailedException: Installing Python requirements failed!
File “/home/klipper/kiauh/kiauh/components/moonraker/services/moonraker_setup_service.py”, line 185, in install
self._run_setup(new_instances, create_example_cfg, interactive=interactive)
File “/home/klipper/kiauh/kiauh/components/moonraker/services/moonraker_setup_service.py”, line 363, in _run_setup
self._install_deps(interactive=interactive)
File “/home/klipper/kiauh/kiauh/components/moonraker/services/moonraker_setup_service.py”, line 442, in _install_deps
install_python_requirements(MOONRAKER_ENV_DIR, MOONRAKER_REQ_FILE)
File “/home/klipper/kiauh/kiauh/utils/sys_utils.py”, line 267, in install_python_requirements
raise VenvCreationFailedException(log)
utils.sys_utils.VenvCreationFailedException: Error installing Python requirements: Installing Python requirements failed!
[ERROR] Error while installing Moonraker!
I’m not a Linux pro, please help. I clearly missed something or didn’t read it thoroughly.
Thank You!
What is this? Is your storage full?
Nope, i have 32GB SD card, and it used about 15 %
For now it standing on building wheel for uvloop…
It seems like throthling
I don’t think, that this is necessary.
Kind side note: When pasting code or similar, please use the Preformatted text feature of the forum editor. Information may get lost without that.
Sure, thank you!
Hi @V2m
How did you tell you were only using 15% of the space on the SD card? Could you please share the output of df -h?
klipper@orangepione:~$ df -h
Filesystem      Size  Used Avail Use% Mounted on
udev            182M     0  182M   0% /dev
tmpfs            49M  1.9M   47M   4% /run
/dev/mmcblk0p1   29G  9.6G   19G  35% /
tmpfs           243M     0  243M   0% /dev/shm
tmpfs           5.0M     0  5.0M   0% /run/lock
tmpfs           1.0M     0  1.0M   0% /run/credentials/systemd-resolved.service
tmpfs           243M  4.0K  243M   1% /tmp
tmpfs           1.0M     0  1.0M   0% /run/credentials/systemd-networkd.service
/dev/zram1       47M  3.1M   41M   8% /var/log
tmpfs           1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
tmpfs           1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyS0.service
tmpfs           1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
tmpfs            49M  4.0K   49M   1% /run/user/1000
Hey guys! I don’t understand, what happened. But after last crashing i saw, that monnraker is installed. I cheked services by sudo systemctl status moonraker and it returned me
moonraker.service - API Server for Klipper SV1
     Loaded: loaded (/etc/systemd/system/moonraker.service; enabled; preset: enabled)
     Active: active (running) since Thu 2026-09-03 03:55:21 UTC; 56s ago
 Invocation: cb05948d91bb4e7d926ab8657e6bee76
       Docs: https://moonraker.readthedocs.io/
   Main PID: 1714 (python)
      Tasks: 8 (limit: 966)
     Memory: 33.4M (peak: 34.7M)
        CPU: 5.234s
     CGroup: /system.slice/moonraker.service
             └─1714 /home/klipper/moonraker-env/bin/python /home/klipper/moonraker/moonraker/moonraker.py -d /home/klip>
Sep 03 03:55:27 orangepione python[1714]: Valid: True
Sep 03 03:55:27 orangepione python[1714]: Fallback Detected: False
Sep 03 03:55:27 orangepione python[1714]: Pre-release: False
Sep 03 03:55:27 orangepione python[1714]: Download Url: https://github.com/fluidd-core/fluidd/releases/download/v1.37.4>
Sep 03 03:55:27 orangepione python[1714]: Download Size: 4332247
Sep 03 03:55:27 orangepione python[1714]: Content Type: application/zip
Sep 03 03:55:27 orangepione python[1714]: Rollback Version: v1.37.4
Sep 03 03:55:27 orangepione python[1714]: Rollback Repo: fluidd-core/fluidd
Sep 03 03:55:27 orangepione python[1714]: [klippy_connection.py:_on_connection_closed()] - Klippy Connection Removed
Sep 03 03:55:29 orangepione python[1714]: [klippy_connection.py:_do_connect()] - Klippy Connection Established
I install fluidd.
Then I got in browser interface is running.
For check i bought Rb PI3B and installed klipper without any errors.
