Hello, I recently upgraded my Printer to klipper firmware and changed my Mainboard tp m5p + cb1, but I still want to use my old drivers, which are A4988 and TMC2100. Now I need specific configurations for these drivers to place in cfg file.
thanks
thanks
Hello @CaeZer !
The A4988 and the TMC2100 only can run on standalone mode. So there are no special configurations for that stepper drivers.
Are you saying I shouldn’t write anything in the configuration file?
What should I put in the configuration file for this mode?
thank you
You have to setup the stepper sections as needed for your printer.
My Setup is this :
# This file contains common pin mappings for the BIGTREETECH Manta M5P
# To use this config, the firmware should be compiled for the
# STM32G0B1 with a "8KiB bootloader" "8 MHz crystal"
# and "USB (on PA11/PA12)" or "CAN bus (on PD0/PD1)".
#serial: /dev/serial/by-id/usb-Klipper_stm32g0b1xx_m5p-if00
serial: /dev/serial/by-id/usb-Klipper_stm32g0b1xx_hurakan-if00
[bed_mesh]
speed: 120
horizontal_move_z: 5
mesh_min: 25, 25
mesh_max: 210, 210
probe_count: 11, 11
mesh_pps: 2, 3
algorithm: bicubic
bicubic_tension: 0.
fade_start: 1
fade_end: 10
fade_target: 0
[stepper_x]
step_pin: PC8
dir_pin: !PC9
enable_pin: !PA15
rotation_distance: 40
endstop_pin: ^PD3
position_endstop: 0
position_max: 280
homing_speed: 50
[stepper_y]
step_pin: PA10
dir_pin: !PA14
enable_pin: !PA13
endstop_pin: ^PD2
position_endstop: 0
position_max: 270
homing_speed: 50
[bltouch]
sensor_pin: PC13
control_pin: PC15
z_offset: 0.0
x_offset: -40.0
y_offset: -30.0
step_pin: PC6
dir_pin: PC7
enable_pin: !PA9
rotation_distance: 8
#endstop_pin: ^PC3
#position_endstop: 0.0
position_max: 210
position_min: -2
[safe_z_home]
home_xy_position: 117.5,117.5 # Change coordinates to the center of your print bed
z_hop: 10 # Move up 10mm
z_hop_speed: 5
[z_tilt]
z_positions: 250, 117.5
25, 117.5
25, 117.5
speed: 50
retries: 20
retry_tolerance: 0.0075
step_pin: PB12
dir_pin: !PB11
enable_pin: !PA8
rotation_distance: 33.500
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PC5
sensor_type: Generic 3950
sensor_pin: PA1
#control: pid
#pid_Kp: 21.527
#pid_Ki: 1.063
#pid_Kd: 108.982
min_temp: 0
max_temp: 250
#sensor_type:MAX31865
#sensor_pin: PA4
#spi_bus: spi1
#rtd_nominal_r: 100
#rtd_reference_r: 430
#rtd_num_of_wires: 2
#[filament_switch_sensor material_0]
#switch_pin: PC2
#[extruder1]
#step_pin: PB0
#dir_pin: PB1
#enable_pin: !PC4
#heater_pin: PA7
#sensor_pin: PA2
[heater_bed]
heater_pin: PA5
sensor_pin: PA0
#control: watermark
min_temp: 0
max_temp: 130
[fan]
pin: PA4
#[heater_fan fan1]
#pin: PA3
#[heater_fan SoC_fan]
#pin: CB1: gpio79
#pin: RPI: gpio26
[printer]
kinematics: cartesian
max_velocity: 300
max_accel: 3000
max_z_velocity: 5
max_z_accel: 100
# TMC2209 configuration
#[tmc2209 stepper_x]
#uart_pin: PD9
#run_current: 0.800
#diag_pin: PD3
#[tmc2209 stepper_y]
#uart_pin: PD8
#run_current: 0.800
#diag_pin: PD2
#[tmc2209 stepper_z]
#uart_pin: PB10
#run_current: 0.800
#diag_pin: PC3
#[tmc2209 extruder]
#uart_pin: PB2
#run_current: 0.600
#diag_pin: PC2
#[tmc2209 extruder1]
#uart_pin: PA6
#run_current: 0.600
#diag_pin:
# TMC2130 configuration
#[tmc2130 stepper_x]
#cs_pin: PD9
#spi_bus: spi2
#run_current: 0.800
#stealthchop_threshold: 999999
#diag1_pin: PD3
#[tmc2130 stepper_y]
#cs_pin: PD8
#spi_bus: spi2
#run_current: 0.800
#diag1_pin: PD2
#[tmc2130 stepper_z]
#cs_pin: PB10
#spi_bus: spi2
#run_current: 0.650
#diag1_pin: PC3
#[tmc2130 extruder]
#cs_pin: PB2
#spi_bus: spi2
#run_current: 0.800
#diag1_pin: PC2
#[tmc2130 extruder1]
#cs_pin: PA6
#spi_bus: spi2
#run_current: 0.800
#diag1_pin:
[board_pins]
aliases:
# EXP1 header
EXP1_1=PD5, EXP1_3=PB3, EXP1_5=PB5, EXP1_7=PB7, EXP1_9=<GND>,
EXP1_2=PD4, EXP1_4=PD6, EXP1_6=PB4, EXP1_8=PB6, EXP1_10=<5V>,
# EXP2 header
EXP2_1=PB14, EXP2_3=PB8, EXP2_5=PC10, EXP2_7=PC12, EXP2_9=<GND>,
EXP2_2=PB13, EXP2_4=PB9, EXP2_6=PB15, EXP2_8=<RST>, EXP2_10=<NC>
[display]
lcd_type: st7920
cs_pin: EXP1_4
sclk_pin: EXP1_5
sid_pin: EXP1_3
encoder_pins: ^EXP2_3, ^EXP2_5
click_pin: ^!EXP1_2
#kill_pin: ^!EXP2_8
[output_pin beeper]
pin: EXP1_1
# See the sample-lcd.cfg file for definitions of common LCD displays.
# Proximity switch
#[probe]
#pin: PC15
#[neopixel my_neopixel1]
#pin: PC11
#[neopixel my_neopixel2]
#pin: PC14
#[adxl345]
#cs_pin: PC0
#spi_bus: spi2
is this Correct?
I don’t know. You have to check it with the pinout for your printer board.
I don’t have M5P.
