Changes to PID_CALIBRATE breaks macro
Printer Model: Custom IDEX
MCU / Printerboard: Octopus
Host / SBC Pi 5
…Updated to latest Klipper and I can no longer overload PID_CALIBRATE via macro which I need to enable the safety relay that sits ahead of my beds SSR so the bed will heat.
Config error
  File "/home/pi/klipper/klippy/klippy.py", line 135, in _connect
    cb()
  File "/home/pi/klipper/klippy/extras/gcode_macro.py", line 166, in handle_connect
    raise self.printer.config_error(
configparser.Error: Existing command 'PID_CALIBRATE' not found in gcode_macro rename
Log attached
klippy.zip (284.7 KB)
Yeah, that is unfortunate, and probably should be fixed.
Right now you can reorder the macro in the config, if you define something like:
[gcode_macro PID_CALIBRATE]
rename_existing: PID_CALIBRATE_ORIG
  PID_CALIBRATE_ORIG
After the heater, it should work.
Hope that helps,
-Timofey
Not sure what you mean by reorder it ? This is the macro
description: Saftey relay needs enabled before PID_CALIBRATE will work
    {% set h = params.HEATER %}
    {% set t = params.TARGET %}
    {% if h == "heater_bed" %}
      BEDHEATER_ON
    PID_CALIBRATE_ORIG HEATER={h} TARGET={t}
      BEDHEATER_OFF
In the configuration file, move this [gcode_macro]section so that it is below the [heater] section.
