Printer Model: ender e3
MCU / Printerboard: Fyscet s6
klippy.log log doesn’t needed
Hello ![]()
I want to make bfptouch from +5v coil without using a servo.
Tell me please, how to make a new configuration?
I found out, that I need to use [output_pin]
Here is the working configuration for [bfptouch] in my printer:
[servo BFPTouch]
pin: PA3
initial_angle: 131
maximum_servo_angle = 180
minimum_pulse_width = 0.0005
maximum_pulse_width = 0.0024
[probe]
pin: ^PA0 #using z-endstop pin
x_offset: 0.0
y_offset: 0.0
z_offset: 1.0
speed: 3.0
samples: 2
activate_gcode:
SET_SERVO SERVO=BFPTouch ANGLE=180
G4 P300
deactivate_gcode:
SET_SERVO SERVO=BFPTouch ANGLE=131
A have a little coil it turns on +5v
It has only 2 wire VCC and GND
If we give it +5v, the probe goes down. If we turn off the power, the probe goes back automatically home position.
And I want to make from OptoSensor and this little coil
Some kind of bfptouch. Help me please with configuration. Thank you
