Bltouch BTT skr mini e3 v3
Printer Model: ender 3 pro
MCU / Printerboard: skr mini e3 v3.0
Host / SBC RPI4
klippy (1).log (3.1 MB)
printer (1).cfg (18.9 KB)
BLtouch, i have correct settings for bltouch with correct connection vdd- 5V gng-gnd control signal goes to servo signal and zmin goes to sensor signal on 5 pin, my bltouch is “bltouch smart v3.1”
I tried in printer cfg to use ^ in front of p14 and it did nothing, issues is that the probe fails to deploy, in bltouch itself i will see blue light for short while when it tries to deploy probe , but anything i tried didn’t helped me.
Is it a genuine BLtouch?
Not sure, i bought it some time ago but it worked in the weekend on creality 4.2.2 without issues
And only thing that’s on it it’s " smart v3.1 " and whole pcb was made in black
The bltouch have plastic probe and body from clear black plastic that is little transparent
A genuine BLtouch should look like these: https://www.antclabs.com/bltouch-v3
You may try some options: BL-Touch - Klipper documentation
Ye ,then i have clone with hall sensor
And i was trying klipper doc too, that’s why i wrote here, i tried to deploy the bltouch with command and nothing i even tried “BLTOUCH_DEBUG COMMAND=reset”
And “BLTOUCH_DEBUG COMMAND=self_test”
