Connection issues with Manta m8p
Seckit tank v2
manta m8p
cb1
I recently moved and have been using the printer with no problems prior. After changing the wifi information in the system.cfg file I was eventually able to see the motherboard register on advanced IP scanner. So I know its connected to the internet. The issue is it still won’t connect via ssh or load mainsail.
You’ll have to provide more information. How are you trying to access the system and what is the response that you’re getting?
If you can see the system using Advanced IP Scanner, you should be able to get the IP address of the CB1.
Have you tried to access the using ssh biqu@<IP Address Returned by Advanced IP Scanner>?
Connected to YOUR router or a public router?
How do I check the IP of my router?
I am trying to access the system by sshing through mobaxterm with no results and by refreshing the browser IP for mainsail.
Find (download) the manual for your router and read the instructions.
Most routers have built in Web servers that allow you to manage them. All are slightly different.
You don’t need the IP of your router, you need the IP address of the CB1.
Start up IP Scanner and look for the name of the printer (in the example below it’s “kgpft1”) and read off the IP address:
You don’t need to use any kind of terminal emulator on your computer, In Windows open the “Command Prompt” or “PowerShell” and just SSH from there:
If you’re using a Mac or Linux, open a Terminal window and go from there.
I’m sorry Im replying so late but I successfully ssh’d through command prompt. But still the mobaxterm and mainsail won’t connect…
Just solved the issue. The IP changed from having a 0 to a 1 in the third period. Thank you!
