COPY / MOVE 'gcode' files to the Klipper print folder
I don’t know if it belongs here but I’m happy to share.
A friend programmed a Linux utility to COPY/MOVE gcode files to the klipper print folder.
Function
  1. COPY - after inserting a USB Flash with a file or several “gcode” files
    will be copied to the print folder
  2. MOVE - after inserting an empty USB Flash, all files will be moved
    “gcode” from the print folder
    The folder for printing is set in the “mountcopy” file
     # For Raspberry Pi use
     #DESTINATION="/home/pi/printer_data/gcodes"
     # For BIQU CB 1 module use
     DESTINATION="/home/biqu/printer_data/gcodes"
!! ATTENTION !!
Do not use the USB flash drive while printing.
The file that is currently being printed will be overwritten or moved!
