Cr-touch not working cant save SAVE_CONFIG
Printer Model: Ender 3 neo
MCU / Printerboard: Manta ez3e
Host / SBC CB1
config-20260504-105730.zip (1.4 KB)
klippy (2).zip (7.0 KB)
Hi, i have build a ender 3 neo with a dragonfly bms, now i am making the config i cant get the printer to save config i tried every thing a whole new printer.cfg save config back to the biginning everything and i am stuck because it worked fine half a year ago the error message i got is:
Option ‘z_offset’ in section ‘bltouch’ must be specified
Printer is halted
thanks
Hello @Thijs and welcome to the forum!
How did you get Klipper etc onto the CB1? Did you use a certain tool?
i did use mobaxterm
So you used a step by step configuration, yes?
Maybe a step went wrong.
I recommend to use KIAUH to get Klipper, Moonrakera and Fluidd/Mainsail onto the CB1
so i need to install kiauh with mobaxterm
It’s described here: GitHub - dw-0/kiauh: Klipper Installation And Update Helper · GitHub
