I couldn’t find an up to date Creality CR-X config, so I made one myself.
Currently running mainboard version 2.2 silent version with 2208 steppers
Currently working with the exception of SHARED_HEATER is deprecated.
It still works for now, but a new solution will be needed in the future
I hope this helps anyone looking for a config.
serial: /dev/serial/by-id/
##---- this config, the firmware should be compiled for the AVR atmega2560.
[stepper_x]
step_pin: PF0
dir_pin: PF1
enable_pin: !PD7
rotation_distance: 40
endstop_pin: ^PE5
position_endstop: 0
position_max: 300
homing_speed: 50
[stepper_y]
step_pin: PF6
dir_pin: !PF7
enable_pin: !PF2
endstop_pin: ^PJ1
position_endstop: 0
position_max: 310
homing_speed: 50
step_pin: PL3
dir_pin: !PL1
enable_pin: !PK0
rotation_distance: 8
##-----comment out next line if you do not have a BLTouch
##-----uncomment next two lines if you do not have a BLTouch
#endstop_pin: ^PD3
#position_endstop: 10
position_max: 400
position_min: -6.0
step_pin: PA4
dir_pin: PA6
enable_pin: !PA2
rotation_distance: 23.072855
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PB4
sensor_pin: PK5
control: pid
pid_Kp: 22.2
pid_Ki: 1.08
pid_Kd: 114
min_temp: 0
max_temp: 265
pressure_advance: 0.155
[extruder1]
step_pin: PC1
dir_pin: PC3
enable_pin: !PC7
shared_heater: extruder
[heater_bed]
heater_pin: PH5
sensor_pin: PK6
control: pid
pid_Kp: 690.34
pid_Ki: 111.47
pid_Kd: 1068.83
min_temp: 0
max_temp: 130
[fan]
pin: PH6
[safe_z_home]
home_xy_position: 150, 150
speed: 100
z_hop: 10
z_hop_speed: 5
##-------comment out entire [bltouch] section if you do not have a BLTouch
[bltouch]
sensor_pin: ^PD3
control_pin: PB5
x_offset: 55
y_offset: -6
#z_offset: 7
samples: 2
speed: 6.0
pin_up_touch_mode_reports_triggered: False
## -----These settings need to be updated based on your BLTouch mounting position
[bed_mesh]
speed: 180
horizontal_move_z: 5
mesh_min: 60,6
mesh_max: 290,304
probe_count: 5,5
fade_start: 1.0
fade_end: 10.0
#mesh_pps: 2, 2
algorithm: bicubic
relative_reference_index: 24
[bed_screws]
screw1: 25, 50
screw2: 265, 50
screw3: 265, 270
screw4: 25, 270
[printer]
kinematics: cartesian
max_velocity: 300
max_accel: 3000
max_z_velocity: 5
max_z_accel: 100
