Creality CR6SE not flashing
Printer Model: Creality CR6SE (2020)
MCU / Printerboard:Creality 4.5.2
Host / SBC: Linux mint mini PC
klippy(2).log (93.2 KB)
Hi guys,
i asked a similar question in the subreddit but i figured i would try here.
i have a cr6se that refuses to flash klipper firmware.
for make menu config i made sure to follow the instructions that are in the printer configuration file but i cant seem to see any activity that would indicate the board is actually flashing.
I’ve checked using the ls /dev/serial/by-id/ and there is no board showing up.
so far i have changed the firmware name and attempted to flash the firmware a few times.
i even enabled low level configuration options in the make menu config and disabled SWD at startup thinking it could be an issue but it did nothing.
i have used 3 different USB cables and tried multiple different ports on my PC to see if it is an issue but it all points back to the board not being flashed and i don’t really know where to go from here.
if anyone is able to provide some insight, it would be much appreciated!
as a side note i have an Ender 3 v2 running klipper off the same PC and it works absolutely fine.
