Crowsnest on MKS Skipr
Printer Model: Homebuilt
MCU / Printerboard:MKS SKIPR
I am having trouble getting a camera to work with my MKS SKIPR board. The main problem is that Crowsnest V4 is meant for Bullseye but the MKS SKIPR is still on Buster. I’ve found and followed instructions about using the V3 version of Crowsnest but the git backport repositories do not seem to be supported any longer. The farthest I’ve gotten is most of the way through the V3 install but then there is an error about the backport resource no longer being available. It looks like some people have been able to get the V3 version working on klipper but I’ve yet to see something that works for the MKS SKIPR
I think you can install Bullseye on your MKS SKIPR. GitHub - redrathnure/armbian-mkspi: Armbian Linux Build Framework
@ furry-cheetah for example said it works MKS SKIPR CAN Bus - #203 by furry-cheetah
Good luck, hcet14
Hello,
I have been following that Bullseye project but I was waiting for it to get a bit more mature. SD cards are cheap so I’ll try it out if there are no better options.
Thanks
