Printer Model: Ender 3 v2
MCU / Printerboard: 4.2.7
Host / SBC: Raspberry Pi 4
I have a general hardware question about build plates, obviously the ender 3 is a budget machine, I have spent a significant amount of time tinkering with it. My question is specificallty about the aluminiun build plate,it was nenver the best when i got the machine and over time its hot worse. their is now a bulge in the centre of the plate, Instead of implemnting workarounds to improve ir.
Has anyone triied using a Custom ATP5 Aluminum Plate with Precision Grinding
Material Required: ATP5 Cast Aluminum Tooling Plate (stress-relieved)
Dimensions:
Length: 235mm
Width: 235mm
Thickness: 6mm (or 8mm - please quote both options)
Flatness Specification:
Surface ground to ±0.05mm maximum flatness deviation across entire surface
This flatness tolerance is critical for the application
Machining Requirements:
4 x through holes, 4.5mm diameter
Hole positions measured from plate edges:
Hole 1 (Front Left): 32.5mm from left edge, 32.5mm from front edge
Hole 2 (Front Right): 202.5mm from left edge, 32.5mm from front edge
Hole 3 (Back Right): 202.5mm from left edge, 202.5mm from front edge
Hole 4 (Back Left): 32.5mm from left edge, 202.5mm from front edge
Optional 5th hole (please quote with and without):
1 x center hole, 4.5mm diameter
Position: 117.5mm from left edge, 117.5mm from front edge
Thanks
